Carbbed Swap Q's
Old Oct 12, 2001 | 01:29 AM
ucntcme's Avatar
Carbbed Swap Q's
Ok, so I am considering a Carbbed 305/350 swap (or perhaps TBI, but I hear they don't do so well). I currently have one that *had* a 2.8 ( I know, buy a factory v8, yadda yadda, ain't gonna happen, I have my own reasons).
I have the tranny aspect covered, my question is on the carbbed setup. mainly, what about the existing computer/harness, and the VATS?
IOW, if I do a carb-powered v8 swap, do I simply leave various bits unhooked (covered/sealed of course) or does this setup also require a new harness? What about the VATS in a carb setup, is it even affected (I've heard both ways, both here on the boards and elesewhere).
I know about the brake line move (for motor mounts), I know about the tranny (got that covered), and the exhaust. I know some think that the carbs look off, but that is not a terrible concern for me right now, as I may later swap in a newer FI model when i get more cash-ola.
Thanks, I'll be making my decision in the next day or two.
Bill
Old Oct 12, 2001 | 05:19 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
Well I may not be much help on the v-6 deal, but this is what I did when I took out my TPI. Remove the computer, remove the wires that were connected to the computer. I then ran 2 relays. 1 covered both fans, the other is for the fuel pump. For the VATS, I found the purple wire from the starter going up to the "wire block" on the drivers side. There is a tan wire of the same size as the purple, that went to a little black block with the purple wire. I spliced these 2 wires together.
Joshua Johnston
1991 Z-28
350, T-5, K&N, Ported Vortec heads, Edelbrock RPM, Holley 750 D.P., HEI, 11.07:1 CR, Comp Cams Roller-.510"/.520"-282*/288* dur., Shorty Headers, Dual 2.5 Exhaust, Dynomax Bullet Mufflers, T&R Motorsports custom air intake, Bald tires
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
cstrobel65
Aug 15, 2015 10:19 AM
