350 motor and T5 tranny problems!!
I have 85 camaro with a 305 and a 5 speed manual transmission. I've just pulled out the 305 and replaced it with a 79' 355 out of a truck. My problem is that when i went to bolt the starter it did not match up with 350 bolt pattern. The 350 had a diagnol pattern for the starter. So then the search for right starter with the correct offset began. On the 350 block there is only two holes which are diganol and no third hole.
Break out your drill bits. You have to use the inline pattern, if your block doesn't have it you have to drill and tap the other hole. There is no other way around it.
Found it, Read this...
https://www.thirdgen.org/messgboard/...ML/002835.html
[This message has been edited by 87RS402 (edited October 20, 2001).]
Pac J
May 17, 2020 10:44 AM
monte87cortez
Sep 26, 2015 08:10 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
