I am pulling a 5.7l TPI engine out of a 1987 IROC, any tips?
Old Oct 24, 2001 | 10:31 PM
72Blazerod's Avatar
I want to pull the entire 5.7l engine out of a 1987 IROC-Z to put into my 1972 Blazer 4x4. do you have any tips and descriptions of ALL the stuff I need to pull out with it? For example, where is the VSS unit located? Also where would I find the MAF unit? More importantly, what exactly does the MAF look like? Where is the computer located inside? etc., etc,....
Thanks guys for any info!
Rod
Old Oct 25, 2001 | 08:26 AM
89 CamaroIROCZ's Avatar
Get the TPI Swappers Guide Book. That has everything you want to know.
Matt
89 Camaro IROC
350" GM Crate Motor
650 Holley Double Pumper Carb, Crane Energizer Camshaft (278/290 .476/.494), Edelbrock Torker II Intake Manifold, Hedman Headers, Dynomax Catback Exhaust, B&M Holeshot 3000 Lockup Converter(Yeah, its a little big), B&M Stage 2 Shift Kit and plenty more little stuff that has cost me BILLIONS i'm sure.
Stereo: Sony POS Head unit, Sony Explode Amplifier 200x2 RMS, Pioneer 10" subs, Boston Aqustic 6x9 & 4x6's.
MOD's to come: Vortech heads, 1.6 Stamped Rockers, New Head Unit, and some better 10" subs.
Old Oct 25, 2001 | 08:54 AM
CamaroRS's Avatar
Be sure to bring a set of torx bits to take the intake manifold off (and the rest of the TPI unit if you want to take it all apart instead of pulling it as a whole). Get the whole dual air intake snorkel, the alternator bracket (as the TPI one is different), throttle cable, transmission kickdown cable, cruise control cable and fuel lines. The MAF is attached to the dual air intake snorkel. Label every wire connector you pull so as it will be easier to connect everything when you put it in your car. You shouldn't have to cut the wiring harness at all even on the driver's side plug which just disconnects though you have to get at it from insie the car dash. Be sure just to take your time and everything should go smoothly. I have pulled a couple of these units so let me know if you need anymore help.
Old Oct 29, 2001 | 07:31 AM
RED92's Avatar
Where can I find a copy of the TBI/TPI swappers guide. I haven't been able to locate a copy of that anywhere!
Thanks...
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
The_Phoenix
Sep 3, 2015 10:56 PM
R3500
Aug 17, 2015 12:16 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
