86 Z28, Changing 305 to 350, will Vortec heads fit current belt accessory brackets?
Old Oct 31, 2001 | 10:18 PM
riegerjv's Avatar
Hello,
I have an 86 Camaro, 305, 4bbl, engine code H, it has AC. A shop is
building a 350 and considering using the vortec heads.
Will I have problems with my brackets (AC, Alt. PS, etc..) not matching the
vortec heads, I understand that these heads protrude forward a little, also will I be able to find a intake that will match all the
linkage mounts, etc..
The casting number on the head is 14102193.
Any help or guidance would be very much so appreciated.
Thanks in advance.
James
Fayetteville, NC
Old Oct 31, 2001 | 11:51 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I haven't heard of any problems with getting accessories to bolt up. But, you do need an intake that is made for the Vortec heads, and if you have emissions to worry about, the Vortec heads don't have the exhaust cross-over passage that the EGR valve needs to feed it. This can be overcome by plumbing exhaust up from the manifold to the cross-over passage in the intake, though.
It can be done, but either you or the shop doing the work had better understand up front what the challenges are.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ4 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (ported World 305 heads, Crane PowerMax cam, Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Nov 1, 2001 | 12:28 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
193's are not Vortec's they are Swirl Port's
for truck engines. They do have a regular bolt pattern and ex. crossover passages.
Chronologically challenged. But still kicking!
'92 CAMARO RS
305 TBI 5/spd (now TPI)
B4C Alt.
Cam change:TRW 198/210 ,450/.460 114 LSA
Stock TBI manifolds
'85 IROC Ex.
14.94-92.00 mph
SPDC base and "350" Vortec coming soon!
'69 camaro-BB/Lenco,1050 dominators, /Pump Gas/no drugs 8.97-150+/3200lbs.
SoCal Thirdgen F-Bodies
[This message has been edited by Dyno Don (edited October 31, 2001).]
Old Nov 1, 2001 | 01:23 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Dyno Don is right. What you have isn't a vortec head. Basicly there are two vortec 350 castings which have casting #'s ending in 906 or 062. If you use the real vortecs (which are way better than the Swirl port TPI
TBI head you have) and an edelbrock performer RPM, Check the front alternator bracket bolt hole, right on the front of the manifold.
Mine needed the hole in the bracket enlarged
some to get correct alignment of the alternator with the other engine pulleys...
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
