4.0l jeep motor my friend messed up the timming how can I set it without a light?
Old Nov 11, 2001 | 08:53 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
What is the firing order? just in case I get a timming light what wire should I hook it to? and what should the timming be set at? And how do you ste it by ear exactly? thanks
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Nov 12, 2001 | 11:55 AM
Joshua Leslie's Avatar
if u are not going to use a light, there is no way to "do it by ear" completley accuratley.
The best thing u can do is use a vacum gauge, and idle the motor at 1000rpm, hook up the vac. guage, and then turn the dist. until the highest vacum is achieved.
Frozer!!!
Jan 19, 2024 04:55 PM
italiano67
Dec 11, 2016 09:21 AM
Caspar
Jun 19, 2016 11:19 PM
Andrew6.688
Dec 13, 2015 10:59 AM
Omega
Aug 10, 2015 12:46 PM
