Fuel Injection to Carb
Old Feb 24, 2010 | 09:57 PM
FBM454's Avatar
I'm going from fuel injection to a carb in a 1988 camaro.
Using a electric fuel pump what pessure should I set my pressure regulator?
Old Feb 24, 2010 | 10:14 PM
johnnyb1902's Avatar
Car: 86 IROC-Z
Engine: 406 SBC
Transmission: 350 Turbo
Axle/Gears: 4.10 gears
Re: Fuel Injection to Carb
4-6 lbs should be fine for a carb setup as long as you dont run out of fuel at wide open throttle and if so bump up the pressure
Old Feb 24, 2010 | 10:22 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you're running out of fuel at WOT, you need to increase the volume of fuel delivered, not the pressure.
Old Feb 24, 2010 | 10:41 PM
Car: 86 IROC-Z
Engine: 406 SBC
for instance you have one holley fuel pump w/ a regulator and u set the regulator to 9 lbs and run the hose into a gallon jug and you put the same pump setup into a diffrent jug set at 4lbs. are jugs are gonna fill up at the same time? but if the one w/ 9lbs fills up quicker, then the fuel volume delivered would depend on the pressure, if im wrong about this let me know
Old Feb 24, 2010 | 11:05 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
They'll fill at the same time because they'll be under the same nearly-zero pressure when they're dumping out of an open hose.
Old Feb 24, 2010 | 11:14 PM
Car: 86 IROC-Z
Engine: 406 SBC
so if a carb was running out of fuel at WOT at 4lbs of pressure then bumping up the pressure (as long as it didnt push threw the needle and seat) would not help what so ever?
Old Feb 25, 2010 | 12:03 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Wouldn't help a bit.
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
86Base
Aug 13, 2015 05:06 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
