LT1 swap with A/C
Old Dec 13, 2001 | 06:19 PM
Iroc87's Avatar
LT1 swap with A/C
I read several of the posts dealing with this swap, but I don't recall seeing anything about having A/C. Is it possible, what compressor do I use? stock lt1 or aftermarket? Any info is really appreciated thanks
Old Dec 14, 2001 | 09:16 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Are you talking about the manifold or complete engine swap?
  • 89 Formula 305 WS6
    All the usual suspension mods
    Custom Flowmaster Exhaust
    Tranny Cooler
    Dual gauge pod
    Most "Free" Mods
    3:73, Zexel Torsion Posi
    15.559 @ 88 MPH
    (Not good enough)
Old Dec 14, 2001 | 12:40 PM
mat89RS's Avatar
For the AC , you will need to buy a 90 degree adapter. You can't connect the AC lines because it sits right on the cross member.
LT1 POWERED
HEADMANS HEADERS
300 HP backed with a limited slip, 2.73.
Top speed reached: 150 mph
EATS MUSTANGS FOR BREAKFAST
Old Dec 18, 2001 | 11:06 AM
TexasLT1's Avatar
Car: '92 RS
CarQuest has the adapter he's talking about, thats what I used. if you want, I've got the engine out right now and I can take a picture of it and probably find the part number in all of the receipts. once you get the adapter though, you still have to get the a/c lines. we used standard A/C hose from autozone, and cut off the metal fittings from the old hoses and used hose clamps to put them together. looks factory from the top.
Old Dec 19, 2001 | 01:32 PM
pimpintheRS's Avatar
i am also thinking of doing this swap and i would like to see some pictures texaslt1.. i would also like to know cost and if you could use your old engine mounts..
Shawn
Old Dec 22, 2001 | 08:46 AM
rickyzZ28's Avatar
Car: 1990 RS
Axle/Gears: 3.73 9 bolt
TexasLt1 could you send me the pics please.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
