0411 PCM swap into 85T/A with T700r4... will it work?
Old Mar 18, 2010 | 03:25 AM
evilstuie's Avatar
Car: 1985 Pontiac TransAM
Engine: 400SBC 24x conversion
Transmission: T700r Stage2 Shiftkitted
Axle/Gears: 2.77 9 Bolt
Hey guys,
I'm about to do a vortec/0411pcm swap into the transam, gonna be running around 450hp 383 vortec motor with minram and run x24 sequential injection from efi connection, but i'm a little confused about the transmission...
If i keep my t700r4 which has been strengthened too handle 500hp and shiftkitted, will it overheat or get damaged?
will the tcc lockup will engage mechanically if the pcm isn't controlling it, or will it just float and over heat?
I don't really want to replace the transmission to get it to run reliably, and i don't see the advantages of electronic shift control as i've got a b&m megashifter so i change gear when i feel like it.
So basically can i run the t700r4 and keep it locking up however it does at the moment?
Old Mar 18, 2010 | 03:52 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If it is built for 500 HP, it'll handle 450 HP.
The TCC will not lock up unless commanded. You can set it up so that it locks up via the 4th gear pressure switch, but you're going to have to set up that wiring yourself - the transmission only comes from the factory to be locked up via an external signal (without exception).
It's pretty simple to do - leave the current TCC lock-up power the way it is, but route the return wire (which is simply grounded in the ECM to lock up the TCC) to a "normally-open" single pole pressure switch in place of the one currently in the 4th gear position. The single pole will ground the terminal when pressure is applied, which will complete the circuit to the TCC lock-up solenoid and lock up the TCC.
Old Mar 18, 2010 | 06:07 PM
evilstuie's Avatar
Re: 0411 PCM swap into 85T/A with T700r4... will it work?
Thank you...Capt'n Obvious :P
jokes
Thanks for that, you've saved me close to 5k
The B&M shiftter has a module with a bunch of wires so i'm assuming its either had a kit put on, or its controlling it independently anywa, so it should all be good.
Thanks again mate.
Old Mar 18, 2010 | 06:25 PM
five7kid's Avatar
Wasn't sure why you were asking if 450 HP would overheat or damage a tranny built for 500 HP.
For sure use an axillary tranny cooler in front of the radiator. Even with TCC lock-up, you need to keep the heat down. Synthetic ATF has better heat withstanding properties than standard petroleum ATF as well.
Old Mar 18, 2010 | 08:13 PM
evilstuie's Avatar
yeah, i've got twin trans coolers installed already. its a pretty tricked out transmission.
Yeah I actually work in an oil analysis lab and deal with the stuff all the time. also helps that i can analyse my engine,trans diff oils and coolant whenever i please
Old Mar 18, 2010 | 08:36 PM
five7kid's Avatar
Cool.
midge54
Dec 27, 2019 04:14 PM
Fast355
Dec 2, 2016 06:33 PM
NBrehm
Aug 25, 2015 11:49 PM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
