NEED HELP
Old Apr 30, 2010 | 02:59 PM
1990fbodyfail's Avatar
NEED HELP
i have a 1990 rs with 305 tbi in the car stock i want to put a 350 vortec in there out of a 1996 chevy truck i have the wiring harness and ecu from the truck but i want to keep my 700r4 trans what all do i need to modify in order to get this motor in the car and run
Old Apr 30, 2010 | 03:09 PM
Pocket's Avatar
Car: 91 Trans Am
Re: NEED HELP
Reflash the truck PCM to a manual tune and use a vacuum lockup switch from BTO
You will probably get better advice on the swap from a performance truck forum than on here because the CFI swaps are rather uncommon. Most use the longblock with a better induction setup
Old May 2, 2010 | 08:42 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: NEED HELP
You would also need the TV cable bracket from BTO. The vacuum lockup switch can also be had cheaply from TCI, and theirs is adjustable, or if you want a more complete kit with good instructions, there's the Painless version.
