Bellhousing/flywheel help
Old Apr 30, 2010 | 05:05 PM
1983camaro55199's Avatar
Car: 1983 camaro
Engine: 305 soon to be an 383
Transmission: t5
I have a 168 tooth flywheel on my bord 350 motor. I am currently looking for a starter. But i just read in another post that you cant use this with a T5 transmission is this correct? and why if so? thanks
Old May 2, 2010 | 08:40 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Bellhousing/flywheel help
You need the 153 tooth, 12.75" flywheel, because the 168 tooth, 14" flywheel is a larger O.D. than that bellhousing was designed for. There is NO advantage to a 168 tooth setup, anyway.
