Carb to fuel injection?
Car: 1990 Iroc Z
Transmission: t56
Axle/Gears: 4:10
how can i swap my 350 carbed engine for a 350 vortec fuel injected one? what do i need? how to wire?
Transmission: 4L80E/4L80E
Yes. You would need to wire up all of the wires that come with the EFI system from the donor truck.
I suppose you're talking about swapping this into a truck, right?
Car: 1990 Iroc Z
Transmission: t56
Axle/Gears: 4:10
Re: Carb to fuel injection?
no i was just using that as an example. my camaro was a fuel injected model, the original owner had a 454 in it and took all that out, now i want fuel injection
Well, to be of much help, then, we'd need more specifics.
For instance, I put an EFI LS1 in an '82 that originally came with an LG4. That fits your description.
Car: 1990 Iroc Z
Transmission: t56
Axle/Gears: 4:10
well i have a 350 vortec in it now, with a 4 barrel holly, an i take the parts off a stock camaro 350 with the fuel injection system and place it on my engine?
Assuming you mean 350 TPI, you need a Vortec TPI base.
You'll need a proper fuel pump, of course.
9192camaro
16
Feb 3, 2019 12:21 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
