Which fuel pump do I use
Old Jun 26, 2010 | 04:26 PM
marcos beltran's Avatar
I have 350 tbi engine in my formula and want to put in a better fuel pump. I heard you can use a tpi fuel pump in place of the tbi pump. The question I have is the tpi pump a direct fit or will I have to do any modifications. I really do not want to rig up a pump just trying to keep the car as stock as I can.
Old Jun 26, 2010 | 04:41 PM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
Re: Which fuel pump do I use
tbi?
and walbro255
Old Jun 26, 2010 | 06:38 PM
Pocket's Avatar
Car: 91 Trans Am
Keep the TBI pump
It operates at 14psi, TPIs operate at 43psi, walbros are even higher. If you upgrade to a higher pressure pump the regulator and/or pump are more likely to fail sooner
Old Jun 26, 2010 | 10:02 PM
Car: 90 formula
Transmission: auto
i was figuring it was a typo. just as i thought i cant find any info on a tbi 350 in any 3rd gen from the factory so i was assuming they ment tpi or it is a 305.
Old Jun 26, 2010 | 10:37 PM
Pocket's Avatar
Car: 91 Trans Am
LO5 truck swaps are common. It could be a swap or a seller lied to him to squeeze a few more bucks from the sale
Old Jun 27, 2010 | 12:39 AM
Car: 90 formula
Transmission: auto
id say he thinks its a 350 when its not. hard to mix up tpi from tbi or even carb
Old Jun 27, 2010 | 02:12 PM
Drac0nic's Avatar
Used a 307M (190lph) Walbro with my setup just fine. Bolted in even though the pump was originally for a GN. I have an 89 Astro so even though it "should" work I disclaim myself. Nothing wrong running a stock TPI pump, if you need to bump the FP to tune it later on you can do such. With lightish mods it's a way to skirt around PROM tuning although not optimal you can at least get a chance to reclaim some of the power you're losing due to lack of tune.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
