99 Vortec motor swap to a TH350 trans
Old Jul 2, 2010 | 08:57 PM
supersport92's Avatar
Car: 1992 RS camaro
Engine: chevy 350
Axle/Gears: 3.73 axle
I just got a van with the 99 5.7L motor but it came with the 4L80 trans. I have the TH350 in my car and the only problem i have right now is the flywheel. Can i use the fly wheel from my old 79 350 or is it different, if not what flywheel do i need?
Old Jul 2, 2010 | 10:08 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 99 Vortec motor swap to a TH350 trans
No, you can't use the '79 flexplate. As to which one you need, it has to match the starter. If your '79 engine has been using a 153-tooth flexplate, then the flexplate for any '87-'92 V8 F-car will work. But you probably will find both engines originally came with 168-tooth flexplates. If so, the one from the donor van should work.
Jorlain
Aug 24, 2022 05:11 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
jharrison5
Aug 19, 2015 05:53 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
