Lt1 is it worth it
Old Jul 4, 2010 | 03:16 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Lt1 is it worth it
Hi I have seen a local LT1 engine for $300 with all accesories but withoutthe harness do you guys think this is a good price or can I find one better somewhere else.
Old Jul 4, 2010 | 03:20 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: Lt1 is it worth it
if it's complete it's a decent deal
but you will need the harness and PCM
Old Jul 4, 2010 | 04:59 PM
91camarolt1's Avatar
Car: 1991 chevy camaro rs
Engine: 5.7 cid Lt1
Axle/Gears: stock
Is it rebuilt or are you plaining to add more horsepower. I just bought an Lt1 and rebuilt it with upgrades it cost alot of money. If I bought a regular 350 block and spent the same amount to money on that. I would of have 150-200 more horsepower than the Lt1. You can buy the wiring harness for the mfi I've seen it in summit racing. Don't know that part number sorry. I have the same car as you. 91 rs 305 tbi. transformed it to an lt1 carbutated engine. Not having the best of luck with it at this moment. I'm thinking I should of went with a 4 bolt main 350.
Old Jul 4, 2010 | 05:38 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
He guy said he bought it from a salvage yard and the car had 60k and only the harness is the only thing not included.
Old Jul 4, 2010 | 05:40 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Well right now I have a 350 l98 block but since I seen this on craigslist I was thinking if it would be better then what I have and for the price it is, and since you have carved lt1 can you pm me around how much you spend for all the swapping.
Old Jul 4, 2010 | 10:46 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
If the only thing that is missing is the harness and PCM, you would be cheaper buying a harness (f-body, b-body) and PCM than swapping over to a carb on the LT1, plus it will run better.
Old Jul 5, 2010 | 08:45 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
It's worth it for an S-10. PainlessWiring sells harnesses if Hawk's doesn't have any.
Old Jul 5, 2010 | 11:21 AM
Engine: 5.7 cid Lt1
Axle/Gears: stock
He's not lying there I can vouch for that. My car runs like crap.
Old Jul 5, 2010 | 11:52 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Don't know what you guys did, but it wasn't a nightmare to rebuild my LT1, after selling the transmission off with the harness and computer for $750 from a $900 original purchace, I rebuilt the motor, couldn't have spent more than $300 total (gaskets, HV oil pump, timing chain, ect.), so thats $450 into my rebuilt LT1, spent another $250 for a complete motor with 94 harness and pcm, used the harness and pcm and kept the motor as a spare to rebuild, so you figure $700 total there (both aluminum headed motors), and then $1200 on a T56 swap. I put the motor in my car for less than $2,000 and she runs like a champ for the 3.08 gears I have. I have absolutely no complaints. $300 is not bad, and you probably can find a harness and pcm for $150ish for automatic, and $200ish for manual. F-body harness is pretty good for F-body applications, and B-body is a really good stand alone system.
Old Jul 5, 2010 | 12:46 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
there are 4 models of the LT1,
F-body 5.7l LT1 -Aluminum heads, 2 bolt mains
Corvette 5.7l LT1 - Aluminum heads, 4 bolt mains
B-Body (Caprice, Roadmaster, etc..) 4.3l and 5.7l Iron Heads, 2 bolt mains, both sizes look identical.
94-97 4.3 and 5.7 LT1's look the same, accessories are in different locations between the motors.
92-93 LT1's use an ECM with Memcals (same style as the 90-92 LB9 and L98 motors) and have a slightly different intake manifold, fuel rail crossover tube is at the back of the intake, vs at the front of the intake on the 94-97 LT1.
Old Jul 5, 2010 | 12:48 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
How would buying a LT1 be more expensive to upgrade than a SBC?
1. the intake is good for power. No mods needed at all.
2. aluminum heads are plentiful and easy to port. There are several porters out there that offer heads/cam packages that can make near 400rwhp with about $1200 total.
3. Exhaust is the same as SBC, so any SBC based exhaust system will work without any modification. I'm using the same Hooker 2055 headers and Y-Pipe on my LT1 swap as I did on my HSR'd L98.
The stock harness is easy to modify to work with a thirdgen. There is so much information out there that its sometimes harder to separate the different threads, but the knowledge is there if you know what you are searching for.
_____________________________
I think an LT1 swap makes an excellent swap, certainly a Gen 3 LS swap is better. But its better for the same reasons that a LT1 swap is better. The EFI system is more flexible, the head, and intake flow is better too. Reverse cooling isn't hard to deal with at all either.
My B-body LT1 swap is running 13.5's all day long at 102mph, and that was with 5* of knock retard thanks to valvetrain noise picked up by the sensor. I have a LT4 knock module now and the knock retard is gone but I haven't been to the track yet.
Old Jul 5, 2010 | 04:54 PM
Klortho's Avatar
Car: 1987 GTA
There's nothing at all wrong with an LT1 swap, when people start taking away from how the factory put them together (putting a carb on it and ditching the PCM) you basically have a SBC that was really not designed for a carb, you can find stock f-body or b-body harnesses on e-bay that will work just fine, same goes for the PCM's. I rebuilt my LT1 when the oil pump went out and I think I have a total of about 750 bucks in it, and that's including new valve guides.
Now, I love my LS1, but the LT1 is just as fun to drive as the 4th gen.
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
skinny z
Oct 5, 2015 06:23 PM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
6998poncho
Sep 25, 2015 02:56 PM
