Cam for an LT1 but running Carb and Dizzy ??
Old Jul 15, 2010 | 04:33 AM
Roadkill_58's Avatar
Car: '83 Camaro Z28
Engine: Carb'ed LT1
Axle/Gears: 3.73, LSD
Just in the final stages of building up my LT1 for my '83 Camaro but to this point have overlooked the Cam.
Was originally going to leave it and do it as a "side project" later on but I've been delayed, now, so am considering doing it now.
There's loads of recommendations for cams for Injected LT1s but does it make a difference if the motors running a Carb (GM intake) and HEI dizzy?
I've got uprated valvesprings and roller-rockers already, stock bottom-end (at the moment) and I'm running Dougs long-tube headers and a open system.
It's a manual (T56) with RAM clutch and Aluminum Flywheel (if that makes any difference ???)
Any suggestions would be appreciated . . . . Camshafts remain a dark-art to me, no matter how much reading I do on them.
Old Jul 15, 2010 | 06:18 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Cam for an LT1 but running Carb and Dizzy ??
Any porting work to the heads? What axle ratio? Smooth, medium or nasty idle desired? Daily driver, weekend toy, or track only? If daily, city, highway, or both? Any particular car you want to beat? You gotta give us some guidelines.
Old Jul 15, 2010 | 11:34 AM
Car: '83 Camaro Z28
Engine: Carb'ed LT1
No porting as yet but certainly on the cards - stock bottom end.
Axle is 3.73, LSD.
Medium idle . . maybe a bit more.
Weekend toy / strip during the summer.
Not bothered at all about economy / killing the environment.
No particular targets - just want as much as I can get out of the motor now but also something that would also work if I did a mild bit of porting / bottom end work in the future.
Forgot to add - the carb's an Edelbrock 4BBL (manual choke) but the plan has always been to keep it just to get it running then upgrade when I do the cam.
1.6 ratio roller rockers, comp cam beehive springs.
Old Jul 15, 2010 | 02:43 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Yours is an ideal combo for the GMPP HOT cam. You might want something more aggressive, but you'd be past the point of diminishing returns.
Old Jul 16, 2010 | 02:22 AM
Car: '83 Camaro Z28
Engine: Carb'ed LT1
This the one ??
http://www.summitracing.com/parts/NAL-24502586/
Is it worth replacing the lifters as well ??
Thanks.
Old Jul 16, 2010 | 06:57 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
yep, that's the one. As to the lifters, that depends on the condition of what you have. You can get new GM lifters for $110/set
Old Jul 16, 2010 | 08:06 AM
Car: '83 Camaro Z28
Engine: Carb'ed LT1
There's nothing apparently wrong with the lifters I've got - was just venturing the idea.
Thanks for the help - much appreciated.
Now I've just got to find the $$$ and go shopping.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
cstrobel65
Aug 15, 2015 10:19 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
