distributor help for 350 swap
Old Aug 7, 2010 | 07:27 PM
grx45's Avatar
Car: 87 Camaro Z28
Engine: 355
I am almost done with my engine swap. It is a non computer controlled 350 with holley 670 street avenger carb. The car use to be a 305 with computer controled qjet. The block is from a chevy c10 76-78.
Summit sold me this carb. http://www.summitracing.com/parts/SUM-850001R/
Now looking at it the electrical clips going into it dont match the old ones. And it says that it has no mechanical tach drive. So what do i need to make it work with the tach. Do i need a new tach, did I get the wrong distributor im at a lost.
Eric
Old Aug 7, 2010 | 09:05 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: distributor help for 350 swap
Your old tach connector is different because you had computer-controlled timing before. Now you only need the switched +12V and tach wires. You don't need anything to make it work with the tach. The tach cable drive is for old Corvettes.
Old Aug 7, 2010 | 10:17 PM
grx45's Avatar
Car: 87 Camaro Z28
Engine: 355
So the tach will just work I don't need to connect any special wires for it?
Now i guess i need to find a clip to get the 12v power going to it.
Old Aug 7, 2010 | 10:22 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There's just one wire that'll connect to the tach terminal on the distributor, and it'll work.
Old Aug 7, 2010 | 10:37 PM
grx45's Avatar
Car: 87 Camaro Z28
Engine: 355
Thanks Seems easy enough. Would a local auto part store have a connector that would fit it or do i have to go through summit?
Old Aug 7, 2010 | 10:56 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It'll take a normal .250" blade connector.
Old Aug 10, 2010 | 10:46 PM
grx45's Avatar
Car: 87 Camaro Z28
Engine: 355
Thanks should have the car running this Friday.
Frozer!!!
Jan 19, 2024 04:55 PM
bellez77
Sep 5, 2015 08:39 PM
355sbcTPI
Aug 19, 2015 04:38 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
