383 build question!!!!!!
Old Oct 4, 2010 | 10:44 PM
1985IrocZ's Avatar
Car: 1985 Z28
Hey guys.....quick question, if I have an 1985 305 block, and I want to swap for a 1994 4 bolt main 350, will I run into fitment issues such as alternator brackets, starter, water and PS pump, etc....or is everything the same???
Thanks for the Help!!!
Old Oct 4, 2010 | 11:05 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 383 build question!!!!!!
It's all the same. Apart from oil pans and flywheels, anything that fits one SBC block will fit any other.
Old Oct 5, 2010 | 08:42 AM
1985IrocZ's Avatar
Car: 1985 Z28
so you"re saying that the flywheel and oil pan from my 1985 305 small block is ''not'' the same as the 1994???
Old Oct 5, 2010 | 10:02 AM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
I can not comment about the flywheel but the oilpan should be different because the 94 engine is a one piece rear main seal where the 85 would be the old 2 piece style.
Old Oct 5, 2010 | 11:25 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes, the flywheel and oil pan are different and will not interchange between the two blocks.
Although technically, the flywheel doesn't bolt to the block, it bolts to the crank.
Old Oct 5, 2010 | 03:41 PM
MotorMouth's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
'85 is a 2 piece rear main, has a large bolt pattern and a large end the flywheel bolts to . '94 is a 1 piece rear main, has a small bolt pattern and a small end the flywheel bolts to.
Mickeyruder
Sep 2, 2015 02:45 PM
LT1Formula
Aug 20, 2015 09:36 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
sreZ28
Aug 14, 2015 07:48 PM
