68-75 sbc into iroc.. what flywheel and starter to use?
Car: 88 vert iroc & 95 586hp trans am
Engine: 355
Axle/Gears: 373
original iroc flywheel and started wont fit the older block. need cheap suggestions asap.. was a 305 motor, now going to 350 if that helps.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 68-75 sbc into iroc.. what flywheel and starter to use?
Need 153 tooth flywheel to suit 2 pce seal block.
If your 305 flywheel was 153 tooth no starter change needed
if block doesn't have the 3 bolt holes drilled then 3rd hole can be drilled and tapped for straight across (153 starter ) pattern
Engine: 355
Axle/Gears: 373
no way around it huh? not lookin to take to a machine shop to do.. this motor is just used to pass inspection and will be getting yanked right after.. is the only way to know teeth count, is to coutn each tooth? or will there be a part number?
Transmission: 4L80E/4L80E
You can measure the diameter of the flexplate/flywheel. 14" = 168 tooth, ~12-3/4" = 153 tooth.
gixxer92
May 18, 2017 11:20 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
Damon
Sep 26, 2015 04:29 PM
