454 2bolt main worth it????
Old Oct 21, 2010 | 11:02 PM
robg91z's Avatar
Car: 1991 Camaro Z28
Engine: 350ci TPI
Transmission: built 700r4
Axle/Gears: 4th gen rear end
ok guys one of my friends is giving me a badass deal on a BBC 454..sucks cuz its a 2 bolt main. he is selling it to me cheap. its a whole complete motor but its just disassembled. im not really sure wat year the block is from or wat but it has the peanut port heads. i wanna built this block into a badass motor so do u guys think its worth to build????
Old Oct 21, 2010 | 11:44 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 454 2bolt main worth it????
Nothing wrong with a 2 bolt main as long as you're not going to add any power adders. Even then, a simple main stud kit will make it stronger.
Old Oct 22, 2010 | 12:06 AM
327sleeper88's Avatar
Car: 1988 rs
Engine: 555BBC; Dart, Lunati, SRP, Howards
Transmission: ATI TH-400
Axle/Gears: 35 spline 9", locker, 3.00's
put studs in the mains, and ditch the peanut port heads!! get some brodix Race Rite ovals, or some AFR magnums! The first start to a badass big block is ditching the cast iron heads. they weigh too much. i personally will never use factory heads again for any small or big block build.
Old Oct 22, 2010 | 12:17 AM
robg91z's Avatar
Engine: 350ci TPI
im thinking of stroking it to a 468 i want to build a motor that can hold nitrous..not really planning on spraying it all the damn time but would like that extra power if needed lol. and yes i wanna build a whole different motor out of that block some good flowing heads with a nice choppy powerful cam
Old Oct 22, 2010 | 12:31 AM
Car: 1988 rs
a 468 is a bored out 454, not stroked. You might want to build a 489 stroker. 4.25" x 4.280" (.030" over)
if you want to run nitrous, build a 461 (.030" over), stock stroke. build a middle of the road motor, then let the nitrous do the work. that way you can put some decent money into some good pistons to handle the nitrous.
what kind of budget are you looking at anyways?
Old Oct 22, 2010 | 09:37 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The BBC bottom end is TOUGH, even with a cast crank and 2-bolt main caps. I wouldn't worry about it too much... and if you do build something with some kinda stupid power level, then a 2-bolt block is the ideal place to start - you can have the block machined for splayed 4-bolt caps, which are considerably stronger than a factory 4-bolt setup.
Old Oct 22, 2010 | 09:47 PM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
We stroked my brothers 454 2 bolt main to a 496 with Scat and SRP internals and it is a very dependable engine(It also runs high 6's in the 1/8 in a 3700lb 2nd gen Camaro) He loves it. We plan on spraying it with a 100 shot next year but we wont do any more then that.
Mark.
Old Oct 22, 2010 | 10:51 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
ARP main studded 2 bolt good for about 700 hp?
Maybe 600?
Old Oct 23, 2010 | 12:06 AM
robg91z's Avatar
Engine: 350ci TPI
im not really on a budget i just wanna take it slow and build a badass motor..that 489 and 496 does sound nice
Old Oct 23, 2010 | 12:25 AM
Air_Adam's Avatar
Get the 2-bolt block, have it machined for 4-bolt splayed caps if you plan to go past 600hp, and you won't break it.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
skinny z
Oct 5, 2015 06:23 PM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
