need suggestions please..
Old Oct 24, 2010 | 07:16 PM
91chevyrs350's Avatar
Car: 1991 Chevy Camaro RS
Engine: 350 carburated
Axle/Gears: 3.73 Posi
I currently have an engine that i had in my camaro but the oil pump messed up and something majorly went wrong with that. I have everything on this engine is stuff i had around the house from my father and parts cars.
ok so the block casting number is 3970010 and i know it was a 1974 passenger car and a 2 bolt main.
and the suffix code is cmj which shows nothin hardly but that this is was a 4 barrel motor..
and as of heads i have 14022801 305 head and these are 53cc chamber head BUT with the big valves.
if i use the two together i am aware the compression will be high so i was wondering what kind of cam setup i should go with and some other things.
i also have a 327 block "if this might be better ill get codes of engine" and 283 crank i could use and make a destroked 327 but like i said idk how these heads would work good on what or anything. im going for the most horsepower i can get mid to high throttle with a small budget..
i would like to hear opinions please. thanks.
also i didnt know what cam this engine has in it i do know the person said it was the "biggest" cam they had in stock at there advance auto but i do know it had a pretty smooth idle..
Last edited by 91chevyrs350; Oct 24, 2010 at 07:57 PM. Reason: forgot to mention cam
Old Oct 24, 2010 | 10:21 PM
Re: need suggestions please..
just read something, 302 wouldnt do the best... so what does anyone think about everything else I wrote any help?
darwinprice
17
Oct 11, 2015 11:51 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
gord327
Oct 3, 2015 01:25 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
R13_Braz
Sep 18, 2015 05:00 PM
