Removing SBC frame pads?
Old Nov 12, 2010 | 12:49 PM
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
Hey just wondering what is the most effective way to remove the origanal frame mounts for the SBC motor mounts. I have the back of the car lifted right now so I couldn't look to hard under the front. I thought of just tack welding the underside of the bolts and zapping them out but I dont know if you can get anything under there.
Old Nov 12, 2010 | 01:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Removing SBC frame pads?
Take the A arms out for better access to the nuts inside the K member.
Old Nov 12, 2010 | 02:17 PM
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
Sounds like a good time to change the front springs. I am going to need 6 cyl springs. Maybe i'll just do it all in one shot.
Old Nov 12, 2010 | 05:39 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
I get a huge extension with a swivel head and jack the front end up. It takes like an hour to do it this way and you need somebody to help you... it sucks.
Old Nov 26, 2010 | 04:29 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
that was my thinking too, along with getting new bushing pressed into the arms and some new ball joints while i was at it. worth it to do the job once and freshen things up a bit while you're in there.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
theurge
Aug 21, 2015 12:46 PM
Vintageracer
Aug 11, 2015 08:13 PM
3rdgenparts
Aug 8, 2015 07:09 PM
