I have 1 1982 z28 camaro and its got a 350 engine and i was wondering if there is a ls1 or ls3 conversion kit..or is it best to make a 383 out of it..if so how do i turn my 350 into a 383 stroker?
welcome aboard.
first, the sbc cannot be converted to an ls1; completely different motors. if you're looking to put an LSx motor in your car, its doable. Check out the subforum here:
https://www.thirdgen.org/forums/ltx-lsx/
as for converting the engine to a 383, you'll need at least a new crankshaft, but depending on the age and wear you may want to get it cleaned up and install all new rotating assembly parts.
