vortec 5.7 swap
Old Feb 14, 2011 | 07:20 PM
RicerkillerZ28's Avatar
Engine: soon to be changed 3.1
Transmission: soon to be changed 700R2
vortec 5.7 swap
ok, so im getting ready to start my engine swap on my 91 camaro. im ditching the weak 3.1 and stepping up my game. im putting on a procomp 6 inch single plane intake. the RPM range is 3000,7500. im wondering how the car will cruise at low RPMs. the motor is a 1st gen Vortec 350 with stock vortec heads. I would also like some advice on a good cam that will lay down nice power and serve as a good daily driver. MORE INFO ON THE MOTOR PLAN: its going to have a 650 cfm carb, headers w/true duals, MSD 6AL ignition, and a 700R4 with a trans go shift kit and 3000 stall. any advice on a cam or cruising with that set-up would be helpful thanx!
Old Feb 14, 2011 | 07:49 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: vortec 5.7 swap
Originally Posted by RicerkillerZ28
single plane intake. the RPM range is 3000 -7500.
advice on a good cam serve as a good daily driver
Any cam that runs that high will be a pig down low requiring lower diff gears to let engine spin up faster.
Great for a track car ; crap for a DD . esp lugging around town stoplight to stoplight
Not to mention bad fuel economy
Also the stock bottom end of the old Vortec engine you have is not rated to spin anywhere as high as what the intake " will " go so 1/2 it's rev range is wasted
im wondering how the car will cruise at low RPMs!
It won't , you just leave it in 1st gear to keep the revs up
Have a look at the rev range you use when cruising now and compare it with the range of the intake.
Are they the same?
Old Feb 15, 2011 | 06:01 AM
MassD's Avatar
Car: 1984 Trans Am
Axle/Gears: 3:73
Re: vortec 5.7 swap
Sounds like a victor jr intake. Unless your putting a set of heads that really need to breathe and building a "stout" motor the intake will actually restrict you for street use. I would recommend something in the range of idle-6000 especially if you want to drive daily.
Old Feb 15, 2011 | 09:48 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: vortec 5.7 swap
agree. That is way too much intake.
I really like the LT4 hotcam in my vortec motor.
Are you aware of the lift limits on stock vortec heads? The guides should be milled down to accept higher lift cams. Plus the factory springs arent suitable to any cam upgrade.
Frozer!!!
Jan 19, 2024 04:55 PM
Fast355
Dec 2, 2016 06:33 PM
stalkier
Dec 6, 2015 11:25 PM
pimprs
Aug 24, 2015 11:20 PM
jharrison5
Aug 19, 2015 05:53 PM
