406 iroc build
Old Jul 10, 2011 | 02:41 PM
5spd-iroc's Avatar
Car: '85 iroc-'13 powerstroke H&S tuned
Engine: 406 sbc full roller
Transmission: t5 soon to be t56
Axle/Gears: stock
406 iroc build
hey guys im swapping out my carbed 305 t5 out of my 85 to swap in a 406sbc, specs are 2 bolt main 400 block bored .30 over, 5.7 rods, 11.1 compression, crank turned .10/.10, AFR heads, Vic Jr intake, Holley 750 dbl pumper, hooker shorties for now, comp cams xr274r solid roller cam.
i know about the starter bolt and flywheel counterweight thing, i believe i have those addressed.
my two questions now are the vic intake doesnt have any vacuum ports, i only have the one on the base of the carb, what do you suggest to do to run my vac advance and my power brakes--vacuum tree of that??
and right now i have an adjustable pushrod on order because i have no idea what length is needed for correct geometry, any guesses? pics as soon as i can get them on my pc
Old Jul 10, 2011 | 02:43 PM
5spd-iroc's Avatar
Axle/Gears: stock
Re: 406 iroc build
forgot im running roller 1.5 rockers
Old Jul 10, 2011 | 05:09 PM
Re: 406 iroc build
Just drill a hole or 2 in the side of the plenum.
Your push rods are going to depend on what lifters you use. There's SO MANY different heights of solid roller lifters, it's impossible to predict.
Just make sure you DO NOT use Comps instructions for determining push rod length. They are WRONG. The correct indicator of correct push rod length, is NOT the location of the winess mark on the valve stem; in fact, it makes NOT THE SLIGHTEST DIFFERENCE WHATSOEVER where on the stem the rocker lands. The correct indicator is THE NARROWEST POSSIBLE witness mark. That shows when the rocker's arc is CENTERED on the height of the valve. Find that, then order the next .050" increment shorter of push rod.
Old Jul 10, 2011 | 06:25 PM
5spd-iroc's Avatar
Axle/Gears: stock
Re: 406 iroc build
ok so adjust once its centered to move the least amount back and forth off of center and order .050 shorter?
Old Jul 12, 2011 | 09:50 PM
5spd-iroc's Avatar
Axle/Gears: stock
Re: 406 iroc build
pics as promised
Attached Thumbnails 406 iroc build-img_20110617_214125.jpg   406 iroc build-img_20110708_135805.jpg
Old Jul 12, 2011 | 09:54 PM
5spd-iroc's Avatar
Axle/Gears: stock
Re: 406 iroc build
couple more
Attached Thumbnails 406 iroc build-img_20110708_140449.jpg   406 iroc build-img_20110708_140518.jpg
Old Jul 14, 2011 | 08:09 AM
mark 87gta's Avatar
Car: 87 trans am gta
Engine: 355 ci
Axle/Gears: 327 for now work in progress
Re: 406 iroc build
hey bud im running a victor jr as well trans dapt makes a crab spacer with and addtional vaccum port on it im using it and seems fine
Old Jul 14, 2011 | 12:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The Vic Jr is more intake than you could possibly need with that cam/engine. A Performer RPM would be quite good enough.
Old Jul 14, 2011 | 04:39 PM
5spd-iroc's Avatar
Axle/Gears: stock
Re: 406 iroc build
yeah i got the vic jr brand new for cheap so its goin on for now, i have a weiand stealth intake layin around too if i want to try it down the road
Old Jul 17, 2011 | 07:06 PM
5spd-iroc's Avatar
Axle/Gears: stock
Re: 406 iroc build
well summit sent me the wrong size pushrod checker so i might just make my own in the mean time , threw in and 8.4" pushrod and checked my witness mark was about .050 and a little of center to the exhaust side of the stem
Old Aug 9, 2011 | 02:08 PM
5spd-iroc's Avatar
Axle/Gears: stock
Re: 406 iroc build
waiting on ups with my 351w .060 pushrods and then ill be able to get the motor in hopefully tonight, will post a video of first start asap
Old Aug 9, 2011 | 03:33 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 406 iroc build
WHich AFR heads?
Vic jr is enough intake, but like said above, you can drill into that plenum for a large port and T off that for other accessories, or get a 1/2" spacer and drill/tap a few fittings into that.
Old Aug 10, 2011 | 04:44 PM
5spd-iroc's Avatar
Axle/Gears: stock
Re: 406 iroc build
thier 195's, yeah i tapped the intake for a vacuum tree i had, got her to start today my carb needs alot of adjusting and need to take care of a couple vacuum leaks but happy to have it in and have most everything hooked up, what have you guys done with headers and your ac/powersteering brackets? getting my belts on and cleaning up the harness and hooking the torque arm and driveline is all i really have left
Old Aug 15, 2011 | 03:45 PM
5spd-iroc's Avatar
Axle/Gears: stock
Re: 406 iroc build
heres a crappy video of it running, drove it today it runs good traction could be and issue lol need to buy a standalone fan controller tho as mine doesnt seem to want to turn on through the ecm
Old Aug 15, 2011 | 03:46 PM
5spd-iroc's Avatar
Axle/Gears: stock
Re: 406 iroc build
http://www.facebook.com/#!/video/vid...62841&comments
Old Aug 15, 2011 | 04:16 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
Re: 406 iroc build
Nice build, say boom t5 :P
Old Aug 15, 2011 | 08:46 PM
5spd-iroc's Avatar
Axle/Gears: stock
Re: 406 iroc build
yeah i think the t5's days are numbered
Old Aug 15, 2011 | 11:08 PM
five7kid's Avatar
Unless you don't put any more power to it than a 305 can.
Might as well get something else in there before the T5 is worthless.
Old Aug 16, 2011 | 07:42 PM
5spd-iroc's Avatar
Axle/Gears: stock
Re: 406 iroc build
well i figured this fall would be a good shakedown for the motor anything i want to do different i will and swap in a t56 while im at it this winter
Old Sep 2, 2011 | 04:35 PM
5spd-iroc's Avatar
Axle/Gears: stock
Re: 406 iroc build
http://www.youtube.com/watch?v=06pqKUsf2QU
heres a cold start, its got more of an overlap sound when it warmed up, hopefully get exhaust on it soon and take some more vids
Old Feb 28, 2012 | 11:09 AM
5spd-iroc's Avatar
Axle/Gears: stock
Re: 406 iroc build
figured i would bring this back to life, ive got corvette spyder wheels on the way along with new billet accessory brackets, new 4779 holley 750, new mini starter, dyno dons headers with dual cat y pipe, magnaflow round race mufflers, tires for the vette wheels, and an adjustable throttle bracket for holley 4150's, next week should be a busy week depending if the headers come in or not but got lots to do besides that, going to unloom the harness and roll back all the wires im not using, wire in my fan controller and delete my ac, ill post pics when the parts come in
Old Mar 2, 2012 | 04:22 PM
5spd-iroc's Avatar
Axle/Gears: stock
Re: 406 iroc build
here some pics of the rims that came in today, the wheel is just sitting in the wheel well
Attached Thumbnails 406 iroc build-65793_10150606183147841_723782840_8825085_357698024_n.jpg   406 iroc build-426544_10150606186837841_723782840_8825089_425065571_n.jpg   406 iroc build-417216_10150606178607841_723782840_8825076_1215834879_n.jpg
Old Jun 18, 2012 | 12:29 AM
5spd-iroc's Avatar
Axle/Gears: stock
Re: 406 iroc build
http://youtu.be/UPz1GcklbsQ heres a video of the true dual exhaust all tacked up still need to weld it out and build some hangers, motor is running awesome and stays nice and cool
Old Jun 18, 2012 | 12:30 AM
5spd-iroc's Avatar
Axle/Gears: stock
Re: 406 iroc build
<iframe width="420" height="315" src="http://www.youtube.com/embed/UPz1GcklbsQ" frameborder="0" allowfullscreen></iframe>
italiano67
Dec 11, 2016 09:21 AM
trevor1010
Aug 26, 2015 02:41 PM
trevor1010
Aug 24, 2015 08:34 PM
Regal105
Aug 23, 2015 03:45 PM
mustangman65_79
Aug 11, 2015 03:17 PM
