V8 conversion help!!!!
Old Aug 14, 2011 | 04:19 PM
greeny's Avatar
Engine: Dart 427 SBC
Axle/Gears: Ford 9" 4.10
Ok so I have a 86 firebird with a ton of work done to it. I origanally built the car to make it for the track but it just take way to much money to turn the numbers these guys are turning with these turbos and other power adders. I have a 609 hp dart 427ci small block chevy with and accel dfi fuel injection system. It also has a built 700r4 and a bolt in ford nine inch. A PA racing SBC K-member,front coil overs. It has a spohn trans mount (700r4 and turbo 400) and pro torque arm, QA1 rear coil over kit and a moser ford 9" rear. My new plan is to remove everything i want out of car and put it in a 82-92 camaro 5 speed.
My main question are I want to keep the ac, power steering and 5 spped in the car and put the on my small block. I a not farmilar with the v6 or 5 speed cars. I looked up the parts and they are the same part numbers between the two but are all the brackets to mount up the front the same? Also will the T5 5 speed bell housing mount to the rear or the v8?
Please let me know any information you have. Also pics or other forus know with help.
Old Aug 14, 2011 | 07:50 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: V8 conversion help!!!!
The T5 from an 8 cylinder car will bolt up, but not from a 6 cylinder car.
Your motor will simply grenade a T5 - You'd be lucky to make it to the track, let alone actually drive on it. GM never put the T5 behind even their 215hp 350 motor because it's too weak. You need to look at a T-56 6 speed tranny from a 4th gen car, or better tranny if you want manual.
Old Aug 14, 2011 | 09:54 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
Your going to have to change the motor mounts in the v6 car to v8 mounts and relocate them, they are not the same, which means your going to have to relocate the front brake lines also to accomodate this.
Everything will mount up to the camaro as it is the same frame. Like newbie said, dont even bother hooking a 5 speed up to your block unless you plan on using only 1/8 inch of the gas pedal .
Old Aug 15, 2011 | 08:22 AM
Guest
Guest
Posts: n/a
There's no demand for broken T5s. But choose an '88-'92, then sell the WC T5 for about $600, you're well on your way to a T56 from a '94.5-'97 LT1 F-car.
Old Aug 15, 2011 | 12:12 PM
1gary's Avatar
605hp Dart is pretty rad for street use.Got details??.
Old Aug 15, 2011 | 02:35 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Ditto on needing a trans swap, I am not even sure a built t5 can handle those kinds of #s, especially N/A, like the others I agree t-56 is the way to go if you want it manual, but I would not even think about hooking up that kind of power to a stock t5.
Oh and also like they said, it won't bolt up anyways, the v6 3rdgens use a 60* bellhousing, while the v8s use a 90* bellhousing.
Linson
Oct 24, 2025 02:00 PM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
