a few questions for my first swap please help
Old Aug 16, 2011 | 09:09 PM
majormetallica's Avatar
hi i have an 85 camaro and i recently started an engine swap because i bloew the old 305. next summer i will be dropping in a 350 rebuilt from a 3rd gen camaro, after of course i restore the engine bay and paint the engine. my questions are 1. i removed the engine and not the transmission, when im installing the new one what is th ebest way to go about it because og the spline shaft the comes from the transmission. and one more question. im not sure if it on this site already i am pretty new to it. but when i drop the new one in is there some sort of diagram or walkthrough on where each hose and line go? thanks in advance
Old Aug 16, 2011 | 11:16 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
Re: a few questions for my first swap please help
i would suggest pulling the trans with the motor, much easier process. I also found it alot easier to just take the 2 bolts out of the torque arm from the rear and slide it out rather then mess with the clamshell on the trans, just my 2 cents though
Old Aug 16, 2011 | 11:44 PM
Seven_MPG's Avatar
Car: 1985 Z28
Engine: '69 350 4 Bolt Main .30 Over
Transmission: 700r4/B&M Shift Kit and Flywheel
Axle/Gears: GM 10 Bolt 3.23 Gears
It helps if you use little strips of blue painters tape or masking tape to label all hoses and connections/wires before you seperate them.That way you can just label them 1,2,3,4 and so on.When it goes back together just put 1 to 1,2 to 2 and so on.It would also help if you bought a service manual for your car.
After quite a few swaps I usually don't need to label everything,only some stuff every once in a while.
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
