Wanted: details for swapping a 3.1 v6 EFI with for carb 350
Old Sep 1, 2011 | 01:52 PM
joleda's Avatar
Car: 91 Camaro
I have read a lot of this forums pros and cons on doing an engine swap. That being said, I still plan on changing to the 350. My questions are:
Can you use the v6 auto tranny on the v8 if you change the bell housing? I am looking at the absolute minimum amount of changing that can be done and still have everything work. All advice welcaome.
Thanks,
Dave
Old Sep 1, 2011 | 04:55 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
Re: Wanted: details for swapping a 3.1 v6 EFI with for carb 350
https://www.thirdgen.org/forums/engi...-383-swap.html
My v6 - 383 carb swap
Must have missed this one through your searches
https://www.thirdgen.org/forums/engi...swap-read.html
To answer your question about tranny, No
Need New or used
-motor mounts, clamshells
-front brake lines relocated (mise well change them
-v8 suspension ( completely optional if its just a daily driver )
- Fuel pressure regulator ( all AN fittings add up, be prepared to spend $200 if not more for this )
- Possibly new radiator and fans, not sure if the little v6 can handle cooling the 350, when i took mine out if was small
- Transmission
- wire connectors, maybe switches depending how you will tap into the fuel pump, its computer controlled and will not work unless you put it on a switch or tap into your ignition wires
Believe me, price does add up, dont think its just a simple swap, all those small parts and big parts will cost a few hundred if not close to 1g
Linson
Oct 24, 2025 02:00 PM
RedLeader289
May 28, 2019 01:47 PM
skinny z
Oct 5, 2015 06:23 PM
92projectcamaro
Sep 29, 2015 07:07 PM
Gordonr1973
Sep 29, 2015 11:59 AM
