v6 efi to carbed 305 swap problem ( fuel)
Old Nov 27, 2011 | 01:03 PM
lancefits3's Avatar
hi everyone having some problems with the fuel delivery part of the swap. doing it for a friend
all done, but im having delivery problems
i kept the old fuel pump in the tank and ordered the mallory regulator from the efi to carb swap thread.
when key is first put to key on the pump kicks on and supplys fuel, but thats it after that initial first pump, the pump dosnt run anymore.
fuel supply into reg, from reg to carb, bypass from the reg going to fuel return, vaccum line from carb to regulator
what can this be. and ideas will help im stumped
Old Nov 27, 2011 | 01:26 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: v6 efi to carbed 305 swap problem ( fuel)
the pump is run from the ecm, and the oil pressure switch. the pump wont run unless it senses oil pressure since you no longer have the ecm running it. it should kick on after a few cranks and stay running.
Old Nov 27, 2011 | 02:59 PM
lancefits3's Avatar
if i unplugged the ecm i have no crank nor the initial first pump. so your saying i need to track down the oil pressure sender and connect that wire? what color off the ecm would be for the oil pressure?
Old Nov 27, 2011 | 03:30 PM
travis401's Avatar
Car: 91 Camaro RS
it should already be connected up. if you unplug the ecm it wont crank because the start enable relay needs to be bypassed. its part of the VATS system. you can always run the pump relay trigger wire to a switched 12v source.
Old Nov 27, 2011 | 03:34 PM
travis401's Avatar
Car: 91 Camaro RS
http://www.hotrodlane.cc/newtech/tun...elcircuit.html
this should help
Old Nov 27, 2011 | 04:14 PM
lancefits3's Avatar
okay sweet, im a lil confused on the relay diagram.
which wire should i cut to gve it 12v key on? the one from the ecm right?
im not new to wiring but i was never good at relays lol
Old Nov 27, 2011 | 04:24 PM
travis401's Avatar
Car: 91 Camaro RS
itll be the green wire. thats the one thats triggered by the ecm. tan should be getting the 12v out to pump and has a tan wire from the oil pressure switch spliced into it and also a tan wire the goes back to the ecm as a refence.
Old Nov 28, 2011 | 06:14 AM
lancefits3's Avatar
would it be easier to take the tan wire and suppl it with key on 12 v power?
Old Nov 28, 2011 | 09:08 AM
travis401's Avatar
Car: 91 Camaro RS
you want have the power run through the relay. applying 12v just to the tan wire will bypass the relay altogether.
Old Nov 29, 2011 | 07:34 AM
lancefits3's Avatar
okay. so the green wire turn that into a keyon 12 v sourse?
Old Nov 29, 2011 | 09:30 AM
travis401's Avatar
Car: 91 Camaro RS
yep, you just have to remember that that means the pump will run with the key on all the time.
Old Nov 29, 2011 | 10:26 AM
1987firebird2.8's Avatar
Car: 87 firebird doin 350 swap
ok if i put a carbed 350 in my car and wanna run the mechanical fuel pump what all do i do and can i pull the computer if i use the machanical pump instead of electric
Old Nov 29, 2011 | 10:38 AM
travis401's Avatar
Car: 91 Camaro RS
you have to drop the tank, and remove the electric pump. and either put in a carb pickup, or mod the current one into a carb pickup like the sticky shows.
Old Nov 29, 2011 | 10:53 AM
what if i wanna put in a fuel cell
Old Nov 29, 2011 | 10:55 AM
travis401's Avatar
Car: 91 Camaro RS
a fuel cell in a street driven vehicle is a dumb idea. youll have to custom fab everything from the mounts to the fuel lines. and itll probably cost around $500 minimum just for the cell.
Old Nov 29, 2011 | 11:00 AM
ok forget that idea lol whats gonna b my cheapest choice?
Old Nov 29, 2011 | 11:13 AM
travis401's Avatar
Car: 91 Camaro RS
drop the tank and pull the pump and mod the pickup. only other option is wire the pump to run and either use the mech pump as a regulator (if it has a return line) or ditch the mech pump and get a return style regulator.
Old Nov 29, 2011 | 06:30 PM
lancefits3's Avatar
my design for a custom cell would fit in the stock location. but a cell is kinda pointles it dosnt save much weight unless you use a 5 gal cell. if you want a sump buy the sump kit and get someone to weld it in.
on my personal car with my 406 i gutted the original eletric pump and hardlined it for the machanical pump. i hate eletrical lmaoo.
midge54
Dec 27, 2019 04:14 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
