383
Old Nov 30, 2011 | 07:33 PM
camaroboy199290's Avatar
Car: 89 iroc
Engine: 355tpi
Transmission: jasper 700r4
Axle/Gears: 4.11 lsd
383
alrite iv built a 383 it has the eagle 3.75 stroke crank 6 inch rods and a set of kb icon forged pistons, the cam is a edelbrock 2201 Duration 296/300, Lift .539/.548. it has a proform gear drive and a set of world products sportsman II heads with the 200cc runners and 64cc chambers so itll put my compression around 10.7-1 and my real question is, is the cam i put in the motor gonna get all the power it can outta the setup i have thanks in advance
Old Dec 1, 2011 | 05:19 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 383
234/238 @50 duration of that cam is ballpark with what most are running in good 383's
with 195/ 200 heads.
Depending what the heads flow you might use some more lift (1.6 rockers )
Comp 08-467-8 cam is a popular 383 cam
230/ 236 but with 570 /576 lift
Old Dec 1, 2011 | 02:38 PM
Car: 89 iroc
Engine: 355tpi
Re: 383
well if i switched to 1.6 rockers would i have to change anything else up like springs or anything and how will the springs that the heads came with hold up to the cam
Old Dec 3, 2011 | 12:56 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: 383
dont need to change anything else. the 1.6 rockers give you roughly a .03 boost in lift over 1.5 rockers. you just need to double check that your heads can handle that extra lift without contact issues. and the check that the springs can handle the lift before coil bind.
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
