89 ta 350 swap some gauges dont work help
Old Jan 26, 2012 | 09:05 PM
reaperracer666's Avatar
bought a 89 formula previous owner did a old sbc 350 swap tach, oil presure, and temp gauge dont work they added little aftermarket gauges on a bracket to fix this but they look like crap where do i start to get the stock gauges to work so i can get rid of these
Old Jan 28, 2012 | 06:59 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 89 ta 350 swap some gauges dont work help
Depending on what aftermarket cr*p you have,
they may (most likely ) use the stock sender units in which case all you have to do is connect
the old wires from the dash gauges to the correct sender ( tacho wire goes direct to coil )
If aftermarket senders have been fitted then you will need to fit stock ones
Old Feb 6, 2012 | 10:33 PM
ok that helps kind of
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
bellez77
Sep 5, 2015 08:39 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
