400sbc - 700r4
Car: 83 c10, 2015 silverado
Engine: 454, 5.3
Transmission: Turbo 35o, 6l80
Axle/Gears: 3.42, 3:23
400sbc - 700r4
i need to know if there is 168 tooth ext balanced flywheel that will bolt up to the stock TC i dont know the bolt pattern size of the TC that would help alot on its own thx!
Transmission: 4L80E/4L80E
Sure. Just look on Summitracing.com, or most any chain parts store should be able to get you one.
Come to think of it, I actually have one...
Re: 400sbc - 700r4
Any 14" flex plate will work; at worst, you might have to elongate the holes very slightly. Emphasis on "very slightly". It's like, the difference between an even # of Englich units and an even # of metric units; and most of em, the holes are big enough to take up the tolerance.
Car: Iroc 88
Engine: 350 LT1
Axle/Gears: 10 Bolt 4:11
Car: Iroc 88
Engine: 350 LT1
Re: 400sbc - 700r4
ok, just saw flywheel. Didn't see he said 700r4 http://www.jegs.com/i/TCI/890/399373/10002/-1
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
