v6 to v8 need nelp
Old Apr 19, 2012 | 10:17 PM
firebirdfreak87's Avatar
Car: 87 firebird did V8 swap
Engine: sbc 350
Transmission: 700r4 shift kit and stall
v6 to v8 need nelp
ok I'm doing the 2.8 to 350 swap and I have to rerun the fuel lines does anyone have a easier way to get the lines to passenger side so I can run mechanical fuel pump
Old Apr 20, 2012 | 11:39 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
What I did is gently bend them downward toward the K-member, then ran the supply and return line across the front of it. I used aluminum line to make it easier to form. The last few inches were rubber to the mechanical pump.
I found some tie wrap mounts that popped into a 1/4" hole. I think I used 2 or 3 to hold the lines in place.
This is a nice place to run them away from engine and exhaust heat. They aren't unduly exposed, either. I ran it that way for 10 years (until I did the LS1 swap) without any issues.
ssean92
Oct 2, 2002 06:57 PM
Jester
Sep 16, 2001 04:31 PM
