Smog Question in California
Car: 1991 camaro
Engine: 3.1L V6 dynomax exhaust
Transmission: 700r4 auto
Axle/Gears: 89 iroc-z 9bolt disc+posi 3.27
So I have a registered 1991 v6 engine swapping a 1991 z28 l98 v8 engine.
Will I have any smog issues ?
Will I have to get a referee ?
What exhaust should I go with to I need a new exhaust.
Re: Smog Question in California
the short version
Donor engine must be same year or newer and same class of vehicle car/light duty/heavy duty. All emission controls from donor vehicle must be present, then you smog and probably fail due to engine swap and make appt with referee, they inspect all equipment related to engine swap and when done put a label usually in door jamb that makes it so any smog station can smog.
For exhaust since referee inspection may be needed I say use a stock GM system.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
the short version
Car: 1991 camaro
Ok so I should stick with stock heads and cam as well
Car: 1991 camaro
Car: 1991 camaro
"All exhaust emission controlled vehicles with engine changes must be inspected by an official referee station and must have a Bureau of Automotive Repair (BAR) Vehicle Identification Label affixed to the doorpost."
Car: 1991 camaro
So is the referee a 1 time thing? And how much does that cost ? 100$ I'm assuming. I thought Don does tuning all the time to pass emissions ?
My fear for you is though when it is smogged the v-6 to v-8 will be a automatic flag.
Do you currently have all your swap parts?
I have done several of these swaps and never had to go to the referee.
In fact I called them and they said no.
Car: 1991 camaro
Car: 1992 Chevrolet Camaro Z28
Engine: 5.7 TPI
Transmission: 700R4 Overdrive Automatic
Axle/Gears: 3.23:1 Positraction
Shouldn't have to go with a stock GM exhaust, my L98 Z28 has the Flowmaster exhaust and it passes smog every two years I take it. Just keep the catalytic converters and don't go with headers, keep the L98 exhaust manifolds.
Car: 1991 camaro
Do you have a part number to the flowmasters? I'm going to reuse my cats.
I meant PRE-cat stock exhaust, after the cat it doesn't matter what you do.
Car: 92 25th anniversary edition
Transmission: 700R-4
Axle/Gears: 2.73's
Here's the thing...it really depends on how knowledgable and how much experience the smog tech has. Also really up to his discrection. IF the V6 car is fully dressed like a V8 car from the factory you cannot tell the difference visually. He may be suspicious if he sees the original emission label for the V6 and and obviously its not. Peel off the original emission label and go get a V8 label. IF the tech is sharp and notices the VIN character for the engine isn't correct he can send you to the referee. You can have aftermarket parts as long as it meets CARB standards and has the E.O. number or label for it.
I used to do smogs for 20 years in Ca and I wouldn't send you to the ref if everything was there and hooked up properly.
Just remember everything has to be there and working. Timing has to be set to within +/- 3degs from the spec, EGR has to work, and EVAP has to pass the leak test, including the gas cap.
IF you go LS(x) definitely you need to go the referee.
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
That VIN may denote V6...wouldnt he be held to V6 Emission standards??
Google the smog ref they are right by Pierce College in Winnetka.
