88 bird lt1
Old Jun 18, 2012 | 05:43 PM
dsmexcel's Avatar
88 bird lt1
OK i know you guys are tired of answering this but I got a 88 bird had v6in it no tach in dash i got the car with no motor . I bought a lt1 with harness and computer and trans do I still need the the stock computer under passenger dash if not what wires do I need to keep not running AC in car n for the driver side wire harness. I know one goes to head lights what do I need to keep on the other one that also has wire that lead in to the firewall just above the bell housing what do I keep need help any info is a plus I am also toggling the fuel pump n what about the speedo new trany has electric
Old Jun 18, 2012 | 07:37 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 88 bird lt1
Originally Posted by dsmexcel
do I still need the the stock computer if not what wires do I need to keep
https://www.thirdgen.org/forums/ltx-...questions.html
What is toggling the the fuel pump?????,
it runs automatically off the computer or OP switch
Old Jun 18, 2012 | 08:06 PM
dsmexcel's Avatar
Re: 88 bird lt1
The lt1 came with engine harness and I will not be running AC so do I need the original computer that is under the dash on passenger side? My fuel pump will be on a toggle switch and there is no tachometer in the car so what wire do I need to use off of the drivers side harness
87v6Bird
Jul 1, 2018 04:12 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
