Carbed vortec swap parts list
Old Aug 10, 2012 | 07:15 PM
blue birdy 87's Avatar
Car: White 84 z28
Engine: Chevy 350
Axle/Gears: Posi and?
Hey my old 305 is sounding really bad lately so im conidering swapping for 350.
What do I need to buy to carb a vortec in my originally lg4 car? Or is it the same as a regular sbc swap, because its carbureted not fuel injected. And do I need to buy anything to make the carb go onto the vortec intake?
Old Aug 12, 2012 | 02:51 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: Carbed vortec swap parts list
Edelbrock sells a few different carb intakes for the vortec heads- Performer (2116), Performer RPM (7116) , RPM airgap (7516) and Super Victor (2913). if you are going to use the stock carb, then you need the Performer 2116. if not, choose one of the other ones and know that you probably won't be able to shut your stock hood. if emissions legality is something you need to worry about, then you need the vortec intake from GM that has the mount for the egr valve and you will need to rig up a tube to get the exhaust gas from the exhaust manifold/header to the egr port.
-edit- just looked on the Summit site, and i cant' find the GM egr intake any more..
along with the intake, you need the vortec specific intake gaskets and mounting bolts.
other than that and the need to run the vortec water pump due to the way it runs the coolant bypass to the front of the intake instead of in the block, it drops right in place of your stock engine and everything hooks up the same.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
midge54
Jan 29, 2017 07:00 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
1nastygta
Aug 8, 2015 07:38 PM
