402+t56?
Old Aug 13, 2012 | 01:38 AM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
402+t56?
I have a 71 325hp 402 that I am thinking about rebuilding as my first motor. I understand that the 396/402 has a neutral crank does that mean I can use an off the shelf t56 flywheel.
Old Aug 13, 2012 | 06:46 AM
1gary's Avatar
Re: 402+t56?
The one thing I don't get is the 402's aren't a 396 or a 454.Hummm,that could mean they are really cheap to buy.Right??. Big question is WHY??. Just some food for thought. Oh they have the same wt as a 54,but not the same power.............
Old Aug 13, 2012 | 02:23 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Re: 402+t56?
A 402 is just a 396 with a factory overbore that makes it just a hair bigger. They were even called 396s
Old Aug 14, 2012 | 12:28 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You can't use an off-the-shelf T56 flywheel because the engines T56s came behind were one piece rear main seal. As you might guess, a '71 402 is 2-piece rear main seal.
But, you could use a neutral-balanced 2-piece RMS flywheel made for a T56.
