Pre and post 86 Blocks - compatibility
Old Jan 27, 2013 | 03:52 PM
85FBTranam's Avatar
Car: 1985 Pontiac Trans Am
Transmission: BW T5, Hurst Short Throw Shifter
Axle/Gears: 3.70 Posi
Okay, still confused if I am over complicating this. So in 86 there was a switch from GM from a 2 piece rear main seal to a 1 piece rear main seal.
Does this mean that if I want to do an engine swap on my 85, I have to use a block with a 2 piece rear mail seal?
If the 1 piece RMS block has the flywheel will it not just bolt up to my Borg Warner T5? Assuming the starters and teeth on the flywheels are the same? Or did that change too?
Most of the crate engines out there are 1 piece RMS engines so looking for some help on this.
Thanks in advance.
Old Jan 27, 2013 | 05:36 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Pre and post 86 Blocks - compatibility
You just need to a flywheel to match the crank and everything else works the same.
Old Jan 27, 2013 | 05:53 PM
85FBTranam's Avatar
So the flywheel diameters are standard for small blocks, just the number of teeth to match the starter?
Old Jan 27, 2013 | 06:19 PM
diablizzard's Avatar
Car: 86 Camaro Z28
Engine: LT1 200cc Ai heads and cam
Axle/Gears: 4.10:1 Zexel Torsen
It's the bolt pattern and the pilot hole for the flywheel
Chuck84TA
Jul 15, 2016 09:05 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
gixxer92
Sep 1, 2015 04:32 PM
lakeffect2
Aug 23, 2015 08:44 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
