Starter fitting questions
Car: White 84 z28
Engine: Chevy 350
Axle/Gears: Posi and?
Ok so I have my starter from my automatic transmission, that came off the old style flex plate (I cant remember the tooth count)
Will it fit on the flywheel from my 84 camaro's t5?
Posted from Thirdgen.org App for Android
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: Starter fitting questions
Depends on the tooth count.
An easy way is to look at the starter bolts, if they are straigt across its for the 153 tooth, if they are angled its for a 168 tooth.
Your T-5 flywheel should be a 153 tooth.
Transmission: 4L80E/4L80E
If I recall correctly (and I've never had a T5 car), the T5 starter nose is different from the auto tranny starter nose. The T5 starter will fit auto, but not the other way around.
Unless the starter has been replaced sometime in the past (high likelihood) with one that will also fit a T5 (not as likely).
Car: White 84 z28
Engine: Chevy 350
I have a mini starter because my y pipe was in the way of the oe one.
Nothing like having all pertinent information in order to give a useful response...
Car: 1971 Camaro
Engine: 427
Does your mini starter have 2 sets of mounting holes? If so it will work for either tooth count.
Car: White 84 z28
Engine: Chevy 350
