My latest project. Time for a new engine!
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I have some free time, so I figured I'd make a build thread.
Dart SHP 427 SBC
Eagle 4340 forged steel crankshaft
Eagle H-Beam connecting rods
Mahle forged high performance aluminum pistons
AFR 220 Heads (65cc)
Hydraulic roller cam: Duration @ .050" Lift: 242/248. Lift: .576/.600. 112LSA.
HSR Intake
10:5:1 Compression
Dart SHP 427 SBC
Parts:
Hooker 2210's before:
After:
Painted:
Cam install:
Heads installed along with Morel lifters:
Oil pan/pump on. CC's Pro Magnum rocker arms on:
Ready to drop in:
L98 and 700R4 are out. Just ordered a rebuild kit and torque convertor from Dana (pro-built automatics).
Dart SHP 427 SBC
HSR Intake
10:5:1 Compression
Dart SHP 427 SBC
Parts:
After:
Painted:
Cam install:
Ready to drop in:
Car: 1988 IROC-Z
Engine: 427 SBC
Car: 1988 IROC-Z
Engine: 427 SBC
Re: My latest project. Time for a new engine!
Thanks guys!
Since the engine and transmission are out. I figure I might as well get one of these:
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
I'm only here for those pools.
Car: 1988 IROC-Z
Engine: 427 SBC
Well, pretty much completed the engine today. Threw a header on to see how it looks:
Ran into an issue though. Not enough room to plug in the knock sensor connector. Any ideas?
Transmission: 4L80E/4L80E
Try the other side?
Car: 1988 IROC-Z
Engine: 427 SBC
Guess I'll have to and hope I don't run into the same issue. But that would also include cutting and extending the wire to the other side correct? I don't even know what gage wire to buy. Electrical stuff is my absolute weakness. I stay away from it if possible. Lol.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Dont reallly need it haha if you tune plugs but perhaps you can mod the connector to attach from side instead?
Car: 1988 IROC-Z
Engine: 427 SBC
Hmm I wonder if that's possible. I'll
give it a look later.
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Yep. Just move it to the other side and extend the wire.
Been there,done that a few times.
Engine looks great! A few of my friends keep trying to talk me into a stealthram and over 800rwhp, LOL
Car: 1988 IROC-Z
Engine: 427 SBC
. I'd like to put low 600's to the wheels with this engine. But I have a feeling it will be in the 500's. Last edited by IROCThe5.7L; Apr 28, 2013 at 06:40 AM.
Car: 89 Iroc-z
Transmission: TH400
You may need a bigger cam and maybe more head for 600 at the tires. Making 500's is no joke for a n/a motor. This motor should make lower 500's as that is around 600 hp crank
Car: 1988 IROC-Z
Engine: 427 SBC
A lot of the SHP 427 builds I've seen that were 650fwhp+ all had solid rollers and much more lift. I'd be happy with low 500's. Any guesses on 1/4 and trap speed?
Car: 87 GTA Trans Am
Axle/Gears: 10 bolt posi 3.23
Did you have to clearance that block at all? What stroke are you running? How much stroke do you think it can run?
Are you running a normal base circle cam?
GREAT build.
GREAT build.
Car: 89 Iroc-z
Transmission: TH400
Not sure what your car weighs but if its in the 3450-3500 lb range with you inside, 500 whp should get you 10 secs and close to 130 mph
Car: 1988 IROC-Z
Engine: 427 SBC
I didn't have to clearance the block. I'm running a 4" stroke. I think Dart recommends 3.750 max. But plenty of people are using 3.875 - 4" stroke. Comp cams claimed if I wanted a hydraulic roller they couldn't go down to a .900 base circle camshaft. Mine is 1.000”. The engine does have extra clearance rods which I'm sure helps me not have interference issues.
Wow 4"!!
Thanks!
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
Those hookers usually drop in nicely AS you are lowering the engine. With the tubular K member, you solved a lot of fitment problems. Those 2210's touch the factory A arms and K member in a few spots, requiring clearancing.
Goodluck! Looks stout! 10.70's at 130mph all day with a good converter/tires.
Car: 1988 IROC-Z
Engine: 427 SBC
Not much of an update. Just cleaning the engine bay where I couldn't reach with the engine in there. Going to start installing my UMI K-member & A-arms this weekend. My convertor came in the mail. Just waiting on my rebuild kit from Probuilt Automatics.
Car: 1988 IROC-Z
Engine: 427 SBC
Finally got my rebuild kit from Dana last week:
Some elbow grease:
Back from the shop. They cleaned it up way better than I could and then painted it. This was what I was waiting on. Shouldn't be long before I have her running:
The shop was like "You broke that trans huh?". I was like no? It started slipping on the 2-3 WOT shift after the H/C/I install. But other than that it was fine. Then they showed me this they pulled out of my trans:
Yikes, either I was very lucky. Or that broke when I pulled it into the garage to start the engine swap. I doubt it would be drivable if that sunshell was broke like that.
Some elbow grease:
Car: 1988 IROC-Z
Engine: 427 SBC
Old K-member out:
New K-Member in with transmission:
Ready to go in:
Engine and transmission in (Next time they both go in together, what a pain).
Only issue I have is I removed ball joints. Dropped a arms, dropped old k member. Put new k member in, attached a arms, put springs in, and put my ball joints back in. And now my front tires are out of wack. With the wheels straight, my passenger side tire kicks out to the left. Camber looks way off. I didn't touch any tie-rods...etc Just the ball joints?
Ready to go in:
Car: 1988 IROC-Z
Engine: 427 SBC
All done. Just needs coolant and transmission fluid tomorrow. I'll clean up the wires after I get her running.
Car: 1988 IROC-Z
Engine: L98 - full intake & exhaust boltons
Transmission: Bowtie 700r4, 2400 rpm stall
Axle/Gears: Borg-Warner 9bolt, 3.45 gears, posi
You've got a great car! Post some videos when you get her up and running. I really would like to see how fast your car goes now with your new motor.
Car: 1983 Camaro
Engine: 385 stoker
Axle/Gears: 10 bolt Torsen Posi 3.73 ratio
I would subscribe twice if I could. Wow what a phenomenal job! Can't wait to see more.
Car: 1988 IROC-Z
Engine: 427 SBC
Thanks guys. In the process I had to take my alternator apart. Now it hums loudly when the ignition is on. I don't feel comfortable starting it with it on. So tomorrow I'm going to replace the alternator and hopefully fire it up. I'll be sure to take vids.
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Where'd you pick those valve covers up from? They look nice. I'm pretty sure those are $275 or so, right? I really want to get a set and do a few modifications to them to really make them "pop".
Car: 1988 IROC-Z
Engine: 427 SBC
Well it started pretty easily. Dad was happy
Idle and rev:
Only issues I'm having is if I set the base timing to 6 it won't run. 10 runs ok. 15 it likes and idles nice. I'm not running the stock chip, and the chip I'm using from my h/c/i L98 has quite a bit of idle timing advance. And my new fan switch appears to be turning on way to early. Last time I checked my temp gauge was accurate. But if that's my only complaints I'll consider myself lucky.
http://www.summitracing.com/parts/pro-141-921/overview/
If you're running the stock serpentine system you're going to have to modify the valve cover or alternator.
Idle and rev:
Car: 1988 IROC-Z
IROCthe5.7L how much power and torque do you think your 427 engine is making?
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
Car: 1988 IROC-Z
Engine: 427 SBC
Car: 89 Iroc-z
Transmission: TH400
That cam is big enough and theres enough cylinder volume that it likely wont run with 6-10 deg base timing. My big cam 400 is the same way. It loves idle advance and needed base timing to be set closer to 12-13 deg and no lower. Else it wouldnt start, or had a very rough idle. Give it what it wants and change base value in bin
Car: 1988 IROC-Z
Engine: 427 SBC
Car: 1988 IROC-Z
Car: 1988 IROC-Z
Engine: 427 SBC
Well it moves. That's a start-lol
Car: 1988 IROC-Z
Engine: 427 SBC
Well I finally got all the bugs worked out just in time to put it away for the year
Runs pretty good with a stock throttle body and a tune from my 350. Hoping with a 58mm TB and some more fuel at WOT to have it run even better.
Runs pretty good with a stock throttle body and a tune from my 350. Hoping with a 58mm TB and some more fuel at WOT to have it run even better.Joined: Sep 2003
Car: 89 Iroc-z
Transmission: TH400
Sounds good i am eager to see how this setup runs once all tuned up
