v6 to v8 swap carb question
Old Jul 14, 2013 | 11:40 AM
draco's Avatar
Car: 1992 Camaro RS 25th Anni.
Engine: 5.0l TBI
Transmission: 700R4 Automatic
Axle/Gears: 3.73 Gov lock
pulling 2.8l for carb'd 305. using stock ccc quadrajet from 85 camaro, as well as the 305. trans is from an '88 trans am, 700r4. what provisions do i need for the kickdown cable and accelerator cable, and is the ccc quadrajet ok to run stand alone ?
Old Jul 14, 2013 | 07:31 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: v6 to v8 swap carb question
You don't have a "kickdown " cable on a T700
Read
https://www.thirdgen.org/forums/tran...-too-fast.html
Esp posts # 24 & 26
and you also need to control the convertor lockup somehow once you have a carb
https://www.thirdgen.org/forums/carb...c-control.html
Old Jul 15, 2013 | 08:25 AM
draco's Avatar
Engine: 5.0l TBI
thanks for the thread reference, I'm aware of the TCC lockup. For some reason I was thinking I had to order a bracket for the TV cable but looking back I think that Camaro may have had a TH350
EDIT
I apologize for using the wrong terminology, I meant TV cable to begin with. The camaro I worked on prior did have a 700r4, we had to order an aftermarket bracket for the cable. I needed that part #, thanks for the reference vetteoz!
Old Jul 15, 2013 | 02:50 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What do you mean by "stand alone"?
A ccc q-jet need a "computer", along with a ccc distributor, O2 sensor, manifold vacuum sensor, barometric pressure sensor, and coolant temp sensor. Trying to run it without any of them will put it into "limp home" full-rich mode. It can get along without the EGR or AIR.
Old Jul 16, 2013 | 08:03 AM
draco's Avatar
Engine: 5.0l TBI
I guess that means the hunt is on for a carb then.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
midge54
Jan 29, 2017 07:00 PM
redmaroz
Aug 16, 2015 11:40 PM
