will e-tec 200 heads work?
Old Aug 1, 2013 | 07:50 PM
Juan_Garza's Avatar
Car: 91 Firebird convertible
Engine: 350 tpi
Transmission: 700 r4
Axle/Gears: 3.73's
I just got some e-tec 200 heads with 64cc and I have a 350 vortec block, my question is will this combo work or is it too much head? What cam and rockers do you recomend for a street friendly car with power? All imput appreciated. By the way running a stock tpi system
Old Aug 1, 2013 | 07:57 PM
Re: will e-tec 200 heads work?
No; no problem; should be fine.
I'd suggest something about like a Comp "503" http://www.summitracing.com/parts/cca-08-503-8
You are no doubt aware that a "stock TPI" won't bolt to those heads, right?
Old Aug 1, 2013 | 08:08 PM
Juan_Garza's Avatar
Engine: 350 tpi
Axle/Gears: 3.73's
Yes Im betting on a base on ebay if I dont win ill go with stealth ram. So nothing on my block has to be changed? Also will my stock roller rockers work on these heads with that cam? How bout my springs? Thanx in advance
Old Aug 1, 2013 | 09:44 PM
Yes they'll bolt right up to your block, no changes.
Not sure about "stock roller rockers"; no such thing on any SBC, EVER. You'll have to give more details about whatever you've REALLY got.
Not sure about the springs they put on those heads; you'll have to check with Eddie about those to be certain. But if memory serves, the odds are at least good.
Old Aug 1, 2013 | 09:53 PM
Juan_Garza's Avatar
Engine: 350 tpi
Axle/Gears: 3.73's
http://www.ebay.com/itm/Edelbrock-60989-E-Tec-200-Cylinder-Head-/111131251669?_trksid=p2047675.l2557&ssPageName=STRK%3AMEWNX%3AIT&nma=true&si=e4Ty0rA%252FJHftIe%252FyzX1qHr5vicQ%253D&orig_cvip=true&rt=nc
These are the heads i got and some of the specs, Heads were recently decked .005, and had a valve job. New seals and screw in studs. Im very new to heads i just have basic mechanic skills, im sorry if some of my questions sound stupid but i always get stiffed by mechanics, thanx in advance
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Reddeath210
Oct 6, 2015 08:20 AM
86IROC112
Aug 17, 2015 02:00 PM
