L31 fuel pump
Old Aug 6, 2013 | 11:58 AM
treep78's Avatar
Car: 1986 Camaro Sport Coupe
Engine: 305 OHV
Transmission: 4-Speed auto
L31 fuel pump
I'm swapping a carb converted L31 into my camaro and it doesn't look as though I can reuse the existing mechanical fuel pump. What should I use instead?
Old Aug 6, 2013 | 05:37 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Find an EFI vehicle fuel tank and swap it in. Doesn't really matter what it came from. Put in a new electric fuel pump in the process, either a replacement TPI pump, or an aftermarket like Walbro 255 (very popular). You will need to use a return-type fuel pressure regulator up in the engine compartment, such as a Mallory 4309.
Or, you can put an in-line electric pump in. That would be best installed as close to the tank as you can get. Whether or not you need a regulator depends upon the pump you get. If it is a dead-head type regulator (which you should NOT use with an in-tank pump), you will need to make sure there is no clamped rubber line between the pump outlet and the regulator.
The factory 3/8" supply and 5/16" return lines are more than adequate for these tasks.
Some (not many) '86s had an in-tank electric pump installed. You might want to check to see if yours, by chance, does.
Old Aug 6, 2013 | 05:44 PM
treep78's Avatar
Engine: 305 OHV
Re: L31 fuel pump
I ended up ordering an external electric designed to replace the mechanical on for carbs.
Old Aug 8, 2013 | 01:52 PM
five7kid's Avatar
Mount it back by the tank, then.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
