Engine swap on a 86 Trans Am
Old Aug 8, 2013 | 07:54 AM
webn237's Avatar
Car: 1986 Trans Am
Engine: 305 TPI 5.0L
Transmission: Automatic with shift kit
Eventually down the road I am looking into twin turboing my 1986 Trans Am. Right now I have the 305 in it. Do you think I should swap out for a 350? 400? Or do you think it'd be fine with the motor I have now if I upgraded it a lot? I figured it'd be about the same price range just to buy a bigger block that way I wouldn't have to put that much more into upgrades. Any sugguestions on what'd be the best way to go about this?
Old Aug 8, 2013 | 01:48 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Twin turbo means all forged rotating assembly, compression and cam designed for the boost.
Building that engine and not installing the turbos will make it a dog. It might run better than the 305, though.
I'd recommend building it once.
You could build the 305 for the twin turbo, but it would cost you about the same as building a 350. Maybe you'd live longer, though.
Frozer!!!
Jan 19, 2024 04:55 PM
Jorlain
Aug 24, 2022 05:11 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
theshackle
Mar 5, 2017 06:37 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
