Engine Swap from 400 Small block TPI
Old Jan 21, 2014 | 12:17 PM
Cody Anderson's Avatar
Car: 1991 Camaro Z28
Engine: 350 bored .40
Axle/Gears: 3.73 Gear Posi
Hello everyone, i was looking into swapping my 400 Small Block TPI engine with a 305 Carbed engine from an El Camino, Any Idea of what all i might need to prepare for?
Old Jan 21, 2014 | 12:19 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Engine Swap from 400 Small block TPI
massive loss in HP?
Old Jan 21, 2014 | 12:20 PM
Yea, i was looking to make this a daily driver, the engine in it now only get like 10mpg or less, the 305 got around 18-20mpg
Old Jan 21, 2014 | 02:09 PM
RyanJB's Avatar
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
I believe the 400 uses a different mount than a Chevy small block so you'll have to change the engine mounts, I believe everything else is the same. The exhaust might be slightly difference because the 400 heads sit slightly higher.
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
theshackle
Mar 5, 2017 06:37 PM
Fast355
Dec 2, 2016 06:33 PM
camaro71633
Sep 1, 2015 10:24 AM
