What should ls1 injectors ohm?
Old Sep 17, 2014 | 10:44 PM
92rsvortec350's Avatar
Car: 92 rs z28 clone
Engine: forged 350
Transmission: 700r4 fully built
Axle/Gears: moser axles eaton posi 3.73 gears
I am planning on running ls1 injectors in my new setup and just purchased some used ones and just want to make sure they are ok.
Old Sep 18, 2014 | 12:45 PM
Pocket's Avatar
Car: 91 Trans Am
Re: What should ls1 injectors ohm?
Ohm them out and write down each value. A bad injector will be significantly higher or lower than the rest, usually +1ohms or greater
Old Sep 18, 2014 | 01:33 PM
Engine: forged 350
I did and got 12.7-13.3 what does a new one ohm? my others ohm 14.5 but they are ford 19#
Old Sep 26, 2014 | 04:10 PM
Pocket's Avatar
Car: 91 Trans Am
Thats well within range. Problem injectors are obvious, as in 15+ ohms for that set. +/- .3 ohms is fine
dbrochard
Sep 19, 2015 08:13 PM
webeeZ28
Sep 14, 2015 12:00 PM
timonator
Sep 10, 2015 07:55 PM
Ranbo108
Sep 9, 2015 12:20 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
