406 Sb Roller Cam Selection
Old Jan 11, 2015 | 12:54 PM
mcweens's Avatar
Car: 1987 IROC-Z & 1991 RS
Engine: IROC-305tpi & RS-357(built)
Transmission: Both-700R4
Axle/Gears: IROC-3.23 & RS-4.10
I am currently in the process of researching and buying parts for a 406 small block for my 87 IROC. My father and I plan on putting the motor together and in the car during the summer. I'll be posting a lot of questions on here about this build. Anyways, I need help selecting a cam for it. I plan to buy a retrofit hydraulic roller cam, and I would like this motor to make 500+ hp at the crank. Hopefully that's not asking for a lot. Here's a list of the parts I have so far:
-1976 400 block: .030 over, splayed (4 bolt)
-Scat 4340 Forged Crankshaft
-Scat Forged Pro-comp I-Beam 6" Rods
-SRP Forged Aluminum -16cc dish Pistons
-Clevite H-Series Crank, Cam, and Rod Bearings
-AFR 220cc Aluminum heads:65cc chamber
-10.1:1 Compression Ratio
-Holley Strip Dominator Intake
-SFI Harmonic balancer & Flexplate
-COMP cams Ultra Pro Magnum 1.52 Roller Rockers
-COMP cams hydraulic short-travel retrofit lifters
I plan to make it a ralleycross/street car. I know there's a lot to consider when selecting a cam, but this is my first ever engine build, so I don't know too much about cams. Any and all help is appreciated, as always.
Old Jan 11, 2015 | 01:31 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 406 Sb Roller Cam Selection
You opposed to a custom grind? Or you want a shelf offered cam?
If you are doing a hyd roller you will want to get the afr 8019 springs.
I would go with something around 242/248 to 248/252 duration at .050". Somewhere in there would make fantastic power on those heads. Anywhere in the 110 lsa range.
Old Jan 11, 2015 | 01:40 PM
mcweens's Avatar
I never really thought of getting a custom grind cam, i figured buying an off-the-shelf cam would be good enough. Price is not really an issue because i have a good budget, but i don't want to spend crazy money for things at the same time. How much do they usually run? I'm definitely open to ideas
Old Jan 14, 2015 | 11:18 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Similar in price sometimes more for billet cores. There are many guys out there.
Lunati voodoo 20120713 would be awesome for a shelf grind for that motor
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
