PCV valve system help!
Old Aug 18, 2015 | 10:05 PM
1985chevydude's Avatar
Car: 1985 chevy camaro,z28
Engine: crate 350,headers,3in exhaust
Axle/Gears: 308------3.73 auburn unit
Hello everyone i just put a pcv valve into the sbc im building for my 85 z28.
I also have a breather on the driver side valve cover
My questions are.
1)were do i hook the hoses up to?
2)what is this piece i need to buy that is supposed to be attached to the back of my intake called?apparentyl some sort of fitting.
3).any recomendations as far as size for hoses ill post pics of my build in the body too
4)finally i have an edelbrock choke block off plate but idk what is the top or bottom of the plate.
Thankyou for any help i appreciate it!
Old Aug 18, 2015 | 10:09 PM
Re: PCV valve system help!
Old Aug 19, 2015 | 01:01 AM
Night rider327's Avatar
Car: 1988 Camaro
PVC valve in valve cover, hose from it to the front center port on carb.
Nipple in rear center port of carb, hose from it to power brake booster
Dist. vac advance can, hose from it to small driver side front nipple on carb.
Plug pass side front small nipple
Fitting/nipple in intake, behind carb on pass. side, hose from it to transmission vac modulator valve if running an auto trans with modulator. If manual trans, then install plug in that hole on intake.
Old Aug 19, 2015 | 06:37 AM
Thank you!!!
Old Aug 19, 2015 | 08:44 AM
What is the name of the threaded fitting i need for my carb on the back?
Old Aug 20, 2015 | 12:29 AM
Car: 1988 Camaro
NPT to nipple or NPT to hose barb
Your power brake booster should be 3/8" line
The threads in back of carb is 1/4-18 NPT
So you would need 1/4 NPT to 3/8" hose barb
I buy mine at the local hardware store. Ace, tractor supply, home depot, lowes, etc will all have the fitting you need much cheaper than the auto parts places.
1992 Trans Am
May 10, 2023 07:19 PM
1fast91
Sep 8, 2015 01:48 PM
backtothe80s
Sep 5, 2015 12:39 AM
