88 camaro 2.8 to 5.7 carb need help
Old Sep 10, 2015 | 04:13 PM
hotrod1988's Avatar
Car: 88 camaro
im trying to find a fuel sending unit to replace the one in it as its for fuel injection and it is now carb but can not find one any ideas or ways to get around this. can any one help me with this?
Old Sep 10, 2015 | 05:24 PM
instaldave's Avatar
Car: 1987 Trans AM
Engine: 355 4-bolt, L98 heads, Holley 650DP
Axle/Gears: 3.70 9-bolt
Re: 88 camaro 2.8 to 5.7 carb need help
I used my factory fuel pump and lines. I activated the fuel pump by hooking the fuel pump wire up to an ignition relay. I then hooked up the Holley 12-803bp fuel pressure regulator with a return so I could use my factory lines. Worked like a charm. This is on my 87 TA.
Old Sep 10, 2015 | 06:19 PM
hotrod1988's Avatar
Car: 88 camaro
Okay that's one-way to get it done. As I can't find a fuel sending unit for a carbonated car any where
Old Sep 10, 2015 | 10:07 PM
hotrod1988's Avatar
Car: 88 camaro
One other thing can I use the fuel sending unit that is for the fuel injection just remove the fuel pump from it?
Old Sep 11, 2015 | 12:18 AM
Night rider327's Avatar
Car: 1988 Camaro
Yes, that's what I did with my 1988 camaro. Pull the pickup out. Measure how long the pump is. Cut you a length of 3/8" dia. steel or alum. hardline that length.
Then pull pump off and put the hardline in place of pump. Use a short length of rubber fuel line and 2 hose clamps... Or compression fittings to join your new line to the pickup.
Mine has been that away for 12 years now.
Old Sep 11, 2015 | 12:21 AM
hotrod1988's Avatar
Car: 88 camaro
Alright cool that's good to hear as I can't find a carb sending unit
Old Sep 11, 2015 | 01:40 AM
Car: 1988 Camaro
If you would rather buy a sending unit, I should have a couple from carb'ed cars. I'm parting out many third gens and 4 of them happen to be older/carb models.
1984 Z28 LG4
1985 Z28 LG4
1987 firebird LG4
1984 TA L69
I have already dropped the tanks on 2, put have not removed the sending units yet.
Old Sep 11, 2015 | 09:44 AM
hotrod1988's Avatar
Car: 88 camaro
If one of them will work how much would you want for one?
Old Sep 11, 2015 | 04:39 PM
Car: 1988 Camaro
$35 plus shipping
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
jharrison5
Aug 19, 2015 05:53 PM
GVMV
Aug 16, 2015 08:01 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
