305 TBI to 350 TBI (87 corvette)
Subscribe
Feb 15, 2016 | 04:59 PM
Hello Chevy lovers!
I have a few questions about an engine swap that was done on my car about 8 years ago. I went from the factory 305 tbi to a 350 tbi out of an 87 vette. First question is about a mini starter. I just purchased one and even with it shimmed the teeth engage too much of the flywheel. What can I do about that? 2nd, when I order parts for the motor such as water pump, radiator etc...should I order by vehicle type, or should I be using the 1987 vette specs when Im at places like autozone, Napa, summit etc? Thanks. Engine is in a 1989 caprice classic.
Reply 0
Feb 17, 2016 | 05:39 PM
Re: 305 TBI to 350 TBI (87 corvette)
The 88-92 V8 F-body front engine accessory drive was largely the same as the 88-93 Caprice. It would be logical for those parts to have been kept and used on your replacement engine. I attached a picture of these accessories from an early 90s Chevrolet.
All small blocks are drilled for a big flywheel starter pattern. In the 80s, all the small blocks were also drilled for the small flywheel starter bolt pattern. If your flywheel is 153 tooth / 12 & 3/4", the starter will have 2 bolts of different length, perpendicular to the crank. If it's 168 / 14", the starter will have 2 equal length bolts in a diagonal bolt pattern.
Lacking pictures or other info about what you bought for a starter, I'll just say the LT1 mini-starter is a good option for the 153t wheel, and the truck stater from approximately 1997 is a good option for the 168t wheel.
Reply 0
Feb 17, 2016 | 06:38 PM
Quote: The 88-92 V8 F-body front engine accessory drive was largely the same as the 88-93 Caprice. It would be logical for those parts to have been kept and used on your replacement engine. I attached a picture of these accessories from an early 90s Chevrolet.
Thanks for the input, I did use the same parts from the front, but bought a new flywheel since the old one was cracked.
Here is the link to the starter that I bought with a detailed description
http://vi.raptor.ebaydesc.com/ws/eBayISAPI.dll?ViewItemDescV4&item=371037133336&category=33578&pm=1&ds=0&t=1455755776323
Reply 0
Subscribe
