454 questions, perf, not how to swap.
Old Apr 4, 2016 | 09:04 PM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
I did pros and cons, settled on a Vortec 350, and yet I can't stop wanting the mighty Rat. The '96-'00 Vortec 7400 heads are the only way I'll try it, on a '91-'95 bottom-end.
The only cam I like is a Comp HR 212/218-110, and I have an old, used Torker 2 somewhere. I'm not shelling out for Hooker's long-tubes, so the best I can hope for is Patriot "mid-length" shorties.
I'd guess maybe 375 HP at 4900 RPM, but is that realistic? Would it be closer to 350? Or closer to 400?
Old Jul 30, 2016 | 06:19 PM
cosmick's Avatar
Re: 454 questions, perf, not how to swap.
I finally got one, feel free to check my build thread in Members' Camaros for pics tomorrow, my 4.6 swap thread for the back-story on getting this engine,
I can't find my old Torker 2-O, I'm considering trying Summit's cheap Chinese dual-plane for now, and I have a few other cams in mind. I think I ruled out a Thumper, I will be trying a Comp HR, I'm leaning more toward the 212/218-110 , because to me off-idle torque is the whole entire point and main advantage of big displacement. I want both rear tires to boil at half throttle in first gear with a responsive torque converter, no looser than a 2000-stall.
But I secondarily want it to not feel out of breath before 5000 RPM, so there's the 218/224-110, which would give the meaner idle, or the marine 218/224-112, which should give the best top-end.
I've posted about trying Hedman shorties, but after much research I'm planning Patriot H8012s, bare.
The GM oil pan kit is up over $200, and my welding has improved, so I'm likely to modify the '99 C3500 pan.
I'll be bolting it to a 700R-4, I have a 2.73:1 rear for the stock '99 cam, but I'm thinking probably the 3.23:1 28-spline axle out of my '94 Camaro, with a Gov-Lock I got from a '99 S-Blazer.
Old Aug 12, 2016 | 07:44 AM
cosmick's Avatar
Now that I'm finally earning good money, my first purchase is an Edelbrock C66-O.
I haven't yet disassembled my own heads, but from Google images it seems they desperately need a lot of help in the exhaust ports, so i will be grinding.
Probably going with a Comp marine HR 218-224 112 510/510 cam and Patriot shorties.
Pics are in my build thread in the Members' Camaros sub-forum.
Old Oct 16, 2016 | 12:50 PM
92 BBC Z's Avatar
Car: Currently have 3 cars and 1 truck.
Engine: 1970&92 Cams,both BBC's
Transmission: LS1 T-56 & PG w/vendor's
Axle/Gears: Built 10 bolt& 9inch w/spool
Try Desk Top Dyno.
marcus_booth
Aftermarket Product Review
Mar 2, 2017 01:52 AM
1MeanZ
Members Firebirds
Feb 17, 2017 02:32 PM
white88TA
Apr 5, 2016 08:07 PM
ray jr
Mar 31, 2016 09:26 PM
Piston454
Mar 31, 2016 06:39 PM
